F2 Code Problem
I can't take credit except searching and found this info.. I will order to see if it fixes my error messages..Tom
All, I hope that this helps
everyone having this annoying problem. The problem is the F2 error that
seems to come on everytime you use the oven. Well, it was driving my
wife crazy, so I finally gave in, and had a GE technician come over to
fix it. :) It cost me $190, with $80 for the part and $110 for the
labor. Had I known what the problem was, I could have fixed it myself
in 10 minutes, and only would have had to buy the part. My loss is your
gain. The technician replaced the sensor, part #WB21X5301 (can find at
(www.geappliances.com (http://www.geappliances.com)); cost is $76. If
you open the oven door, the sensor is on the top left-hand side and is
long and skinny. Instructions come with the part to replace it.
Basically, you unplug the oven, take out two screws, and cut the two
wires to the sensor. You then use wire nuts to connect the new sensor
wires, and push the :) wires out of the oven area into the back panel.
That's it. Problem fixed. Glad I could help out others!! Merry
Christmas!
JakeDecember 11th, 2005, 02:25 PMThanks for the information and update back on this problem you had.:)
You can also buy that same part#WB21X5301 from here, abit cheaper:
Oven sensor assembly (http://www.repairclinic.com/referral.asp?R=1265&N=252618)
