My phone says the card is not ready. I assume it needs formatted. how do i do this?
SOURCE: v3i card formating
I got a solution for a 1gig card, so the 512mb max thing is nonsense.
Check this link: http://motox.info/showpost.php?p=333560&postcount=17
Register there, download the file and open with rar or zip. I formatted my card using the cardreader in my laptop (FAT, not FAT32) and added the files in the above file. Just place the "itunes" and "mobile" maps in the root of the card. Take it out, place it in your phone and voila!
note: works on a 1gig micro sd card. Don't know about 2 or more.
SOURCE: memory card micro sd cannot format
i found something to fix it. or at least it worked for me
http://hddguru.com/download/software/HDDGURU-Low-Level-Format-Tool/LLFsetup.2.36.1181.exe
Install that, then run the program and CAREFULLY select your card from the formatting list
then do a low level format
Then format it on windows or phone or whatever
PLEASE BE CAREFULL NOT TO SELECT YOUR HARD DISK IN THE PROGRAM. IT WILL VAPORIZE ALL YOUR DADA
SOURCE: cell phone how do you format the sd card?
just go memory card in that u find format option
select that & ur memory card will get format or try connectioning ur mobile to pc & format through pc by selecting memory drive right click mouse button select format option in that asked for quick & custom format select one of them & format ur micro sd card
SOURCE: Problems with formating samsung e250 micro sd card
I had the same problem and I tried everything. I couldn't think of anything else to do so I just turned my phone off and back on again. When I went back to the memory card menu on my phone all the folders that I lost re-appeared. I don't know if it would work on other phones but it's worth a try!
"Unsupported media card inserted, format now?" error in your smart phone,
"Media is not formatted would you like to format now?" error,
you need to fix sd memory card errors first and them format you sd card.
