Ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
SOURCE: placed password shut phone down
Which model are you wanting help with - You mention both the 8300 and 8900?
In any case - The 8300 doesn't have a reset button? On the 8900 it may be behind the battery cover if so you will need a paper clip.
The following advice is general to Blackberry's and will help clear the memory and reset issues - These are both the soft and hard reset.
You can do a soft reset using Left Alt, Right Shift and Delete - Hold down keys simultaneously for a couple of seconds.
If that doesn't work - Try power down, remove the battery for a minute or so, re-insert battery and then power back on.
Let me know how you get on with the above - If they don't work - Can you also clarify which model no as I have given you generic advice for both models...
SOURCE: how to unlock the keypad of blackberry 8310 curve?
i found on my 10TH ATTEMPT and after already preparing myself for the mourning process, That as i have a numerical password, after typing 'blackberry' my code will work only with the corresponding letters on the keypad and not to try and 'alt' them to appear on the screen in a numerical format
for example 1234 would be shown on screen as WERS
This saved me and now im backing up my system or (think more simply)
SOURCE: I forgot my password for
You have to reset your mobile..This can be done by codes..I found the security unlocking service at Prounlocking.com .Through this you can reset your mobile easily..
SOURCE: how do i block numbers from phoning and texting my
to block a phone number on a blackberry you need a sim card and the option to be able to do it from your carrier.
SOURCE: Phone Model -Blackberry Curve 9300 Imei .
Hi dear,
Please visit this link and fill up the data required:
http://www.blackberryunlockingcodes.com/
And your BB will fine.
Regards
