1998 Lexus ES 300 Logo
Posted on Sep 24, 2017
Lexus ES 300 will not start
Hello, My LEXUS ES 300 1998 will not start, the last time I started the car was on Christmas eve, and it's been very cold here in Denver. When I did run the car on Christmas eve my fuel light came on, but I did not stop to refuel. I did add two galloons of gas to make sure I was not out of gas, but that still did not work. Any ideas!! I have plenty of power.
5 Related Answers
Anonymous
  • 740 Answers
  • Posted on Dec 18, 2008
SOURCE: 1992 Buick Park Avenue - car runs great..when it runs.
The crank sensor is located on the side of crankshaft damper/pulley it mounted on a bracket. However it think that you may have a map-sensor problem that's very common with this vehicle. The crank sensor is not hard to change at all. Good Luck get back in contact if you need more help
Anonymous
  • 3 Answers
  • Posted on Feb 12, 2009
SOURCE: ES 300 servicing: Lexus Dealer vs. Toyota Dealer
no there is not really a downside dealers are good it doesn't really matter who does it but lexus is more familiar with lexus vehicles than toyota because they specialize in it but something like that is simple .
Dan B
  • 36 Answers
  • Posted on Mar 16, 2009
SOURCE: 92 lexus es300 knock sensor
Need to remove the upper and lower air intake manifold.  There are two knock sensors for the front and rear pistons banks.  If you plan to do this yourself it is about 1 to 2 hours.  While you are at it, there is a short coolant bypass hose sitting in the same spot, replace it.  Another problem with the knock sensor is the wire harness used to connect the two knock sensors into one connection sometimes wears out and contacts the metal on the engine causing false signals to the ECM, so replace this cable also.
Just did this last summer on my 99 ES300.  Pretty easy.
DIYr
Anonymous
  • 5 Answers
  • Posted on Mar 18, 2009
SOURCE: car starts and runs fine then dies
ya could be a bad filter. or maybe your injectors are getting bad.
Anonymous
  • 5158 Answers
  • Posted on Apr 15, 2009
SOURCE: How many O2 sensors on a 1997 Lexus ES 300?
according to the manual i have... it has three.... one in the exhaust manifold.... and two in the exhaust pipe..... slightly vauge on the exact location of the last two sensors... but looks like it is after the catylitic converter.
1helpful
98 lexus es300 does not start
Starter not engaged. No fuel. No spark.
HOW TO RESET THE MAIN ENGINE IN 1998 LEXUS ES
i dont think it would be the computer did you check the fuses if its not the fuses follow the battery cables see if theres a relay on one of the cables or if your ground is bad
Why doesn't the eletical stuff work in my lexus es
how do i find out if the motor wentnout in my moonroof it will not close
4helpful
I have problem on lexus es 300 99 year, when i driving at 70 miles my rpm is going to 4000. My overdrive it does not work. I have check engine light and its code is knock sensor bank 2.
My Lexus es 300 most often when engine is warm will not shift in to last gear. Stop engine start it will shift ok when engine is cool. engine pings kock senores. When in gear at high speed the car runs like new?? Car run bad in hot weather. VSC light on. Red light looks a circle with red line through it comes on not always..
What's a good tire for 98 lexus es 300? good
BF Goodrich Traction TA is a great all season tire and you can get an H speed rating good to 130 mph without breaking the bank
How much does it cost to do tune up on lexus es 300, 1997 model
Hello there here is a good site to give you more information and general idea of the cost involved Lexus ES Forum [Lexus Forum Archive] - Page 3 - Lexus Forums how to tell if it needs a tune up...? what is the value of my ... About how much does it cost to fix a '92 lexus ES300 with a ... 1997 Lexus ES 300 ...www.planetlexus.com/lexus-forums/archive/index.php/f-4-p-3.html - Cached
1994 lexus es 300 200000 miles quit while
PLEASE TAKE IT TO UR LEXUS DEALER AND LET THEM FIX IT ONCE IF IT HAPPENS AGAI DUMB THE CAR
Top Lexus Experts
ROBERT GARCIA
ROBERT GARCIA
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Lexus Expert? Answer questions, earn points and help others
