SAME AS ABOVE
SOURCE: Picture shadow on rear projection Sony big screen TV
OUR TOSHIBA HAS A DOUBLE VISION/BLURRIE PICTURE. THIS PROBLEM IS ALWAYS THERE. SOMETIMES THE PICTURE IS GREAT, BUT MOST OF THE TIME ITS BLURRIE/DOUBLE. LOOKS AS IF IT ALWAYS ON 3D!! ANY SUGGESTIONS? WE WOULD REALLY APPRECIATE ANY HELP WE CAN GET FROM ANYONE. THANK YOU!
SOURCE: blue shadow or ghosting on screen
SOURCE: Panasonic PT-51HX41 rear projection tv showing shadow/double images.
Unplug the TV from the ac wall outlet for about 4 minutes then plug it back in and turn it on. If it still has a double image then tell me if it's affecting the menu screen from the TV (not the cable menu). And is the double image in red and blue?
C-Dog
SOURCE: rear projection tv picture problem
I have a sony kp-48s65 projection tv. I have three lamps in back a red a green and a blue. when turned on the sound always works
timer standby light blinks steady at 1 pace Once in a while the picture will just come on and work fine it may work for 1 hour or 10h min then the picture goes out . What can i do. People say lamps but when the picture is on and working the three lights behind work fine . its like whatever powers the lights isnt working
Unplugging and plugging back in and waiting usually brings it back on. For so long . When it is on the screen I can see hard bright green and red the picture is really too red its ok but its hue is off or something Tv in good shape what do i do?
tv consumer
You have 2 distinct problems that should be addressed separately. Please repost the Samsung problem. I will address the Sony problem here.
If the "shadow" makes the picture seem somewhat of a 3D one, the problem is with the convergence circuit. This could be as simple as bad connections on the pins of the convergence ICs or defective ICs. If you can solder and would like to attempt the repair, update this and I'll provide more details and instructions.
Dan
