I can't boot from flashdisk. allready change the bios boot setting to usb fdd, but still can't boot from flaskdisk. need help. thank you
SOURCE: Memory upgrade - P4M80-M4
Maybe your RAM is not compatible with the motherboard just refer to instruction manual...
SOURCE: Biostar P4M900-M7 SE BIOS ROM Checksum Error
The bios upgrade procedure stopped at half , leaving the bios corrupted. The computer now cannot do a regular boot procedure, this is the reason why it cannot recognise some device. If you are still able to boot from floppy, you can restart bios upgrade procedure from floppy. Just download floppy version upgrade and re do setup. Even if you do not find latest bios version, just download a floppy upgrade that is working, so that you can restart your machine regularly , and then do the update to latest version.
If you are not able to complete the bios setup, the only way to fix your motherboard will be flashing the CMOS chipset with a chip programmer device that will reinstall bios straight into cmos chipset.
You can have this done at the service point, in this case consider also replacing your motherboard.
Regards
SOURCE: Biostar P4M80-M7A motherboard
You're board does not use an integrated graphics card.
Monitor does not have video display. There can only be four reasons why.
1. The monitor's video cable is not connected correctly at each end (Video card & Monitor) or cable is bad.
2. The monitor’s power cord is not plugged into a good power source or cable is bad.
3. The monitor may be bad.
4. * The AGP graphics card is either not seated correctly in its AGP slot, (remove/clean copper contacts with alcohol/allow to dry & reseat snuggly), or graphic's card is bad.
Monitor’s power cord can be switched with the PC's power cord.
The video cable & monitor can be swapped by borrowing from a friend.
(Just make sure their stuff is working first).
Never open the PC case without unplugging the power cord first.
Luck!
Mike
SOURCE: my current graphics driver is VIA/S3G UniChrome
1.Start
2.Control Panel
3.Switch to classic view
4.Device Manager
5.Display Adapters
6.Select your display adapter by double click
7.Driver Tab
8.Update Driver
9.Search automatically for updated driver software.
Your computer will check your hard drive then the internet for the new drivers and it will install them too good luck hope it helped
