Bottom of door seams further away from the gasket. can the door be ajusted.
We have the same problem with our LG washer. Don't think the door can be adjusted but I'm not for sure. I think the gasket is wore out but haven't checked on fixing the problem yet because it barely leaks.
My washer was leaking from the front door because it was overfilling I had a problem with my LG Tromm (WM1814CW) leaking from the front door.
I replaced the boot and the door latch but the washer would still leak after running for 10 minutes or so
After a bit of internet searching, it turned out that my washer was actually overfilling due to a bad pressure switch. It would fill 50-75% of the way and then start leaking out the door. I replaced the pressure switch assembly (part number 6601ER1006E) and the washer works. This replacement was very easy to do.
Here is a video showing how to replace that part (https://www.youtube.com/watch?v=v0pluB3fEA0).
Here is the part shown in the washer diagram https://www.partselect.com/PS3529317-LG-6601ER1006E-Switch-Assembly-Pressure.htm?SourceCode=12&ModelNum=WM1814CW
IM LOOKING FOR A LG INTELLOWASHER 7KG DOOR SEAL MODEL NUMBER WM-1175FHB THANKYOU
The rim of the door seal that touches the glass door isnt sealing right and a new door seal will fix it try taping a bit of kitchen towel just below the door when you start ur next wash this will save you having to sit and wait for it to leak
