See this causes and fix it. God bless you
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a
tripped circuit breaker or a blown fuse. Check the wall socket for
power with a voltmeter or by plugging something else in. Sometimes
the power cord disconnects or burns at the dryer, if this is the
case, the wiring and the terminal block must be repaired or
replaced.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the
door switch if found defective.
Most dryers have a door switch actuator lever - when you close a
dryer door, it presses against the lever, which actuates the door
switch. If the lever is broken, the switch would not activate and
the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch
assembly and it is recommended to get the whole assembly since there
is almost no price difference between the door switch assembly and
just the lever. Check your model for more details.
Thermal Fuse
The thermal fuse helps to prevent a dryer
fire by shutting off power to the dryer if it overheats. If the dryer
won't start check this fuse first. Test the thermal fuse with an ohm
meter or continuity checker. This is the most common part to fail when
the dryer won't start. Once the thermal fuse has blown, it has to be
replaced. It can not be reset.
