For formatting the handset,you can dial *#7780#....than it will ask the security code you have to give the default code as 12345 or you you can give your personal code which you have given…this will not delete any data from your handset…other way is to do the hard reset that will delete all the data for that youi have to dial *#7370# again it will ask the security code similarly you have to given ealier
for formatting the handset,you can dial *#7780#...than it will ask the security code you have to give the default code as 12345 or you can give your personal code which you have given ..this will not delete any data from your handset..other way is to do the hard reset that will delete all the data from your handset..and for that you have to dial *#7370# again it will ask the security code similarly you have given earlier
Turn off the phone. Press green call button,* and 3 simultaneously. Then press power switch till you see the formatting screen...
Try usin software to unload lock code.
Plese give me all code of 6600 & password
Three methods
1. *7780#
2. *7380# or
3. prees call,* and three
simultaneously and switch on ur mobile untill formatted screen appears
Note:-Battery must be fully charged.
Type *#7370# you see the formatting screen Select yes to format.
*7073# or #7378# or #7078#
Here is the proper link to format nokia 6600
http://www.fixya.com/support/r546989-format_nokia_6600_mobile_phone
Thank you very much the solution above are so helpful
Sory mas...w dah lakukan cara pertama...tapi kok malah blank sama sekali...!!! gmn cara...???
Find your solution from the list,
Nokia 6600
Codes:
Software & Hardware Problems
Find Your Solutions for Nokia Phones:
Nokia N95
Nokia N73
Nokia N70
Nokia 6300
All the other Nokia Phones.
My phone 6600 have a virus, i installed already the anti-virus, but the virus still their
Few minutes ago my memory card is totally working.when i formated my card my phone is showing memorry card curropted.What can i do?
T67777777777777777
Nokia 6600 can not copy any file to my pc.
If anyone forgets his nokia 6600 security code then he can recover it, by using the MCODE application which can be downloaded freely from: http://users.net.yu/~dejan/download/mcode.zip
thanx....
If you face problems like nokia 6600 gallery is not opening,
camera is not working, Bluetooth device of mobile is not working, mobile is
operating much slowly, u’r celll is infested by viruses like commwarior (we’ve
an alternate solution for this )..and many other problems then first RESET your
phone so that it’ll get the original factory settings. First format by secret
codes here and then if the codes failed go for full hard formatting via keys
(step 3). Resetting just solves many problems and if the problem still persists
go for other alternatives found in our ‘PROBLEM SOLVER’. RESETTING PHONE BY NOKIA SECRET
CODES â (steps 1 and 2) 1st step : SOFT RESETTING NOKIA 6600 A Soft-reset is the process of resetting all the settings of the phone to
the factory default! No applications are deleted. Take backups of 2nd step : HARD RESETTING BY CODE A Hard-reset is like formatting a memory disk. Itâ formats the phone memory.
Everything that has been installed other than default apps at d time of
purchase are deleted.The phone’s setting will be restored to the time when you
purchased the phone.Default apps are not deleted. Just enter the code- NOTE: FLASHING 3rd step :’FLASHING 6600′ : ANOTHER METHOD FOR HARD FULL FORMATTING If any of the above methods failed to make your phone formatted then try
this step-mainly try this step if the problems are following-blank screen phone
unable to boot, phone is only able to boot-up to Nokia screen ,unable to
uninstall any installed software, unable to delete certain files on C
drive(phone memory).This step is known as flashing of phone. Always do this
step at last (after 1st 2 steps are over and u are not successfull) as these
problems might be solved by resetting using codes. To format the (restore factory settings) phone here is a way .
â *#7780#
It will ask for “Restore all phone settings-phone’ll restart….”
Then it asks for security code enter
*#7370#
The battery must be full or the charger has to be connected to the phone so
that it does not run out of power and make the phone unusable.
Take backup of the contacts and other important data in MMC .
â
â 1. Make sure you phone is fully charged. (At minimum 3/4 of bettery should be
left)
â
â 2. Backup your contacts list and personal files to MMC memory card (if
possible).
â
â 3. Switch-off your 6600 phone.
â
â 4. Press and hold these three keys together
â
â -Green dial key,-Star key (*)-Three key (3)
â
â then press the power on/off to swtich on the 6600 phone.
â
â Do not let go the three keys until you see the “formatting†screen
displayed
â
â 5. After a few minutes, the format will be complete. Your 6600 will now be at
its original factory settings (It will reach the same state as that in when you
purchased it). All inbuilt applications provided by nokia will not be deleted)
My nokia 6600 have a virus, i installed already the anti-virus, but the virus still their
SOURCE: Mobile Formating
No there is no risk in formatting your Nokia 6600. Firstly ensure the battery should charge by atleast 75%, then take out your memory card from the phone . Press * , 3 , OK , all these three buttons simultaneously & Switch-ON the handset while keep pressing all these three buttons. Your phone will start formatting. After formatting your phone will work absolutely normal.
SOURCE: MMC memory card is corrupted (1GB). does not format.
Please try to format the memory card using a memory card reader on computer and then insert the card back in phone, it will say corrupted again, but now you try again to format it from phone and it should work now,,.....
SOURCE: i want to play mp3
hi there!
nokia 6600 classic can play .mp3 files for it have its own music player. meaning you can just upload .mp3 files on your memory card, put it in the phone and viola! but if you want to use another music player, you can download realplayer, winamp, etc but this will only add memory to your memory card and may slow down the phone's performance since this is the classic type. you can download these software from cnet.com or brothersoft.com to make sure you get it from safe freeware sites. =)
plese give me all code of 6600 & password
how to format my phone
format nikia 6600, please give me code
how to unlock ma nokia 6600 to format it
how to format my phone? pls give me a code
i already tried the three steps in reformatting.But I cant open still open my gallery files and cant take pictures on my 6600
My NOKIA 6600 Cellular Phon Is Affected By a Vierius.I Want to Format My Phone....So plg Help me on This...........?
my 6600 is infect by virus how to formatt it??
ineed to formet momery card
i want formate my phone
i want format the mobile fully
not charging
how to reset code password
my phone gallery is always busy even i get one Snape
it is showing "temporary overload continue" like that what i want to do
