Well what happened was i was setting password for supervior and the i seen the hard drive password so i set it also but i didnt know that it would come up everytime tthe computer is started up , i looked to see if there was a way to disable it in bios since i do know the password can anyone help ?
SOURCE: Acer Aspire 5100 Bios
Make sure you have all the latest updates found in the Acer site and Windows Update. Windows Update has the hardware update for the Realtek hardware in question. Also, make sure your BIOS has been updated. Make sure you are also running under a Verified XP OS. Aspire 5100 usually comes with Windows XP Media Edition with all the "bells and whistles" Acer has to offer. Unfortunately, most companies that sell "Refurbished" laptops, fail to include an installation disk. So, you'll have to create a Recovery disk via Acer Recovery Disk maker. Folks forget this process and end up with an expensive manila folder.
Ultimately, this is a common problem for a lot of Laptop/Notebook users, and it really just takes constant care and caution to make things work. Most problems arise when you stop caring.
Finally, do a Complete system Audit by using a very useful program called WinAudit. It will tell you EVERYTHING you need to know about your notebook/PC. It will also help your knowledge of what is running on your computer and how to fix them.
Also...
(Make sure you have Admin rights for this one.)
Check your Device Manager by holding the Windows button and pressing the Pause Break button (close to the DEL button on the upper right hand corner) Click the Hardware tab. Then the Device Manager button. When the window pops up, click View> Show Hidden Devices.
You will notice that a few devices with a "Caution" mark on them. These are the devices that end up causing problems with startup and system failure. If you feel adventurous, you could disable the devices with little or no problems. Unless you have a Parallel and Serial Port on your Aspire 5100, get rid of them for good.
But, it's not the ONLY problem. If you have no Device errors pop up, and the same problem occurs, then the best thing to do is to take it to a "Trusted Certified Professional."
Good Luck
SOURCE: acer aspire 3100 series
If you where the CMOS battery is, there's beside it a jumper inserted in two of the 3 pins(left pin and middle pin). Remove the jumper from its original position and with it short the middle pin and right pin. This resets the CMOS ROM to its default settings minus the password. Return the jumper to its original position as before. Reboot the computer.
SOURCE: removed my CMOS battery, but the BIOS settings won't disable
There are 2 ways you can reset your bios.
1. On the motherboard there is a small watch battery. Remove this battery along with the power cable from the power supply. Hold down the power button to fully discharge the system. Wait 2-3 minutes then reinstall the battery and plug in your system. Your reset is now complete
2. Some motherboards have a 3 pin jumper by the battery. Lets say that the jumper is on pins 2 and 3. Remove the jumper while the machine is OFF and place onto pins 1 and 2. Power on your machine for a minute. (Note: Your system will not POST). Shutdown your machine and put the jumper back to pins 2 and
3. Your reset is now complete
There might also be an option within the BIOS to "Load Defaults" if that is all you are looking to do
please see this http://www.11a.nu/software/bios-pc-bios-security-and-maintanance-toolkit/
hope it helps!
SOURCE: Bios password for toshiba laptop needs reset
Try This:
Resetting a Toshiba BIOS Password
KeyDisk will reset the BIOS password on Toshiba laptops.
Older Toshiba laptops can be convinced to boot without their power-on BIOS password by attaching a dongle to the parallel port which crosses a number of the pins. The pin out is:
Pins
1-5-10
2-11
3-17
4-12
6-16
7-13
8-14
9-15
Some Toshiba's can be convinced to bypass the startup BIOS password if you hold down the <LEFT-SHIFT> key while booting the system.
SOURCE: clear bios password on acer aspire 5100-3959
To reset the bios in an acer 5100 you need to remove your DDR2 memory sticks, below you can see "j2", make contact in this jumper turn on your laptop and your bios would be reset
well thank you all who responded after messing with it i got ,frustrated and told my self well you know the password so go into bios and set a the new password to blank what i mean is hit enter for the new password with out typing in anything after doing this it cleared the harddrive password and disabled it bingo dont know why i didnt think of that sooner
