When i click SIM directory this msg appears 'sim card not ready' and when i click copy i only see this option 'from memory card'... How can i copy my contacts from sim to cell phine E-71. please help.............. for call sim card is ready... i can make a call by typing numbers.etc
Try going to storage in the settings menu. See if it says mount or unmount SD card. If not just take out sd card n turn off phone. Turn on. Look in menu, see if phone recognizes there is no sd card. If so, good. Turn phone off. Remove battery 5 seconds. Insert battery and sd card. Turn on phone. Allow total boot process before manupulating phone. Go to contacts. If it doesn't read the sd card automatically then press add contact. See if it has add from sd card
SOURCE: the phone keeps displaying sim card registration failed on phone
The sim card holder is too loose on a lot of new Nokia phones. Place some folded paper (3,4,5,6 times) between the sim card and the sim card holder. It should fix it. I have an E65 and had this problems for two days after buying it. Since I fixed it 3 months ago, never had this problem again. Hope it works for you too.
SOURCE: cannot access SIM contacts or SIM card
If you go into menu and press contacts, options, select sim contents, sim directory and the go back to options and mark/Unmark, then select mark all. Your phone will automatically tick all the numbers on your sim. The last thing is to press options again and copy to contacts.
Let me know how you get on with this but l guess this should fix your problem.
SOURCE: want to copy all contacts to sim card
To copy a phone, fax, or pager number from contacts to your SIM card, scroll to
the contact you want to copy, and select Options > Copy > To SIM directory.
SOURCE: I have a Nokia E71 and using SIM from my old
open "address book", then press "option"scroll down to "SIM contacts" and press the right-navigation key and select "SIM Directory"
It will display contacts on your SIM card. To copy contacts from SIM to phone memory. Select "Options" then scroll down to "Mark/Unmark" press right-navigation key and select "Mark All" then select "Options" again and then select "Copy to Contacts"
That will copy your contacts from SIM to Phone directory.
SOURCE: I have just brought Nokia 5230 2 days back. I
This flashing envelope icon is telling you that your text message storage is full.
1. Go to Messages
2. Select Options
3. Then select SIM messages
4. Select and delete all SIM messages.
This should do it.
All the best!
Testimonial: "Thanks a lot ib_yang for this help. It was really helpful."
