Is on lock. How can i unlock it?
It sounds that your TV is locked by someway. Just unlock it. Proceed the following. •
Look at the screen. If you see a red key on the bottom of the screen,
press "Function" and "Mute" on the remote at the same time.
This will unlock the channel. Do this if you want to bypass the lock to watch a
certain show or channel while leaving the TV locked. All other channels will
remain locked and the TV will lock again when it is turned off. • Unlock all of the channels on the TV by
entering 0711 or 3308. These are the Jensen factory reset codes that will reset
the TV to the original factory settings. By doing this, you will loose any
information that you have stored in the TV, such as channel labels and
schedules. You will have to program the TV again by going through the entire
initial set up. •Call the technical support service number
in your owner's manual if neither of those codes work. A technician can help
you troubleshoot the television as the problem may not be the parental lock
feature. Have the model number and serial number of the TV available when you
call.
Many Jensen TVs have a parental lock that can be set to stop
children from watching certain television shows or channels. In order to
activate or deactivate the controls, you have to know the four-digit code or
parental lock passcode. If you forget the passcode or if the lock gets set
accidentally, you can still unlock the TV.
• Turn on the TV using the remote control. In most cases, you
will need the original Jensen remote to unlock the TV if you aren't sure of the
unlock code. You can purchase an original replacement online if necessary.
• Take your television to a TV repair shop if
neither of the codes work and the TV locked by itself while it was turned on.
In this case, the TV may need to be rewired.
SOURCE: TV Problems
If you hold down the display button, you will lock the tv. Hit the power button and you will prevent anyone from wathing the tv without the remote. The only way to unlock it is by turning the power on with the remote of course (the blue screen should show) and hold down the display button.
SOURCE: child lock has TV locked
Well after spending about 45 mins on hold and searching the internet for the last 2 days the resolution to this issue is to hold the display button down for 3 secs .... Yep thats it Hope this saves someone some time --Brian
SOURCE: Locked out
Hold down On screen display button for maybe 10 seconds. This worked with our Tevion tv we bought from Aldi
