Sewing Machines Logo
Gail Anderson Posted on Sep 26, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to set 2140 for free motion sewing
Hello, the step by step directions in my 2140 manuals are not clear on how to set my Pfaff. 2140 creative to free motion sew.....I have the correct foot, but need guidance on how to set my machine. Thank u for any help u can give me. Thank u so much... Roberta in Ca.
R.A. Ellis
Level 3:
  • Sewing Machines Master 12,731 Answers
  • Posted on Jan 04, 2016
R.A. Ellis
Level 3:
Answers
12731
Questions
Helped
2613474
Points
59176
Use a darning foot or other free motion foot. Attaching this foot disengages the the feed dogs.
Set machine for straight stitch. (Stitch length doesn't matter since the feed dogs have been disengaged and you will be make the stitch length by moving the fabric with your hands.)
Most quilters prefer to have the needle in the automatic down position when free motion quilting.
Test on a practice piece of quilt sandwich and adjust the upper tension to suit you.
That's it!
Consult the manual at 3-9, 5-15 (darning instructions) and page 133-134.
"The Pfaff “Free-motion program”!
Select the “Free-motion program” and the presser foot automatically moves to the embroidery and darning position. Lower the feed dogs conveniently from the front of the machine."
https://www.youtube.com/watch?v=Joc7YXh_4KU
http://www.quiltingboard.com/main-f1/pfaff-2140-free-motion-quilting-t269211.html
mrbios
Level 1:
  • Contributor 24 Answers
mrbios
Contributor
Level 1:
Answers
24
Questions
0
Helped
16839
Points
47
Which model are you using? Creative 4.5?, On the newer machines it drops automatically once the embroidery attachment is hooked up. On older Creatives v2.x there is a slide lever in front of the presser foot on the front.
5 Related Answers
RickE1
Rick
  • 202 Answers
  • Posted on Dec 20, 2008
SOURCE: Timing is off on my Pfaff 2140/2170 machine.
Basically on any sewing machine to time it you will need to separate the two gears that drive the hook. Usually loosen the set screws that attach the gear to the shaft and separate them.
Time the hook first. On center needle position, set the hook so that the point is behind the needle when the needle bar has risen about 2.5mm.
2) Set the needle bar height. Choose the needle position which is the last for the hook to pass.
(Left on most machines, right on older Vikings) At this point, place the point of the hook behind
the needle and set the needle bar height so that top of the eye is just barely below the tip of the
hook.
3) Check feed timing. Set the stitch length to the longest stitch. The needle should enter the
fabric just as the teeth drop below the surface of the plate.
Anonymous
  • 15 Answers
  • Posted on Apr 15, 2009
SOURCE: sewing machine maintenance, walking foot & free-motion foot
Is this a Janome MemoryCraft 9000? (I ask because the models seem to get mixed up in the threads)
If so, you can more than likely find accessories for the MC9000 either on eBay, your local Janome dealer (you can find the closest one to you @ Janome's website using the "Dealer Locator" feature) or even ... SEARS!
Sears contracted Janome to make several of their sewing machines (I think Janome might still be the actual manufacturer, but aren't 100% sure) and so the parts are compatible. You can even use a Kenmore Memory Card with a Janome MC9000.
As for oiling, if it's the MC9000 (much like practically all newer models) they don't need oiling. Though sometimes, you can dab a teeny-tiny amount of oil on the bobbin case if it needs it.
Anonymous
  • Posted on Apr 24, 2009
SOURCE: - resetting the timing
I have been an upholsterer for over 30 years, I own a Pfaff 145 and Pfaff 545. Both are basically the same. Whenever my timing is off, where the threaded needle won't connect with the bobbin thread, I have always had success in re-setting the timing by taking apart the entire bobbin case. Remove the walking foot and the plate it walks on. Remove the bobbin and dismantle everything underneath it. Keep each piece and its screws together, and remember the order in which you removed it (last goes in first, etc.)Remove any obstructions, thread, fluff, etc. Surprisingly, when you put it all back together, your timing will be back to normal. This has always worked for me, and I hope it'll work fo you.
Anonymous
  • 65 Answers
  • Posted on May 22, 2009
SOURCE: need owners manual
We have PFAFF sewing machine instruction books available here:
Pfaff Sewing Machine Instruction Manuals
Anonymous
  • 13 Answers
  • Posted on May 27, 2009
SOURCE: Manual Sewing machine Pfaff 1229
http://www.sewusa.com/Sewing_Machine_Threading_Diagrams.htm
PFAFF creative 1471-sewing foot?
It's not the foot, it is the 'Feed Dogs', the teeth in the base that pull the material UNDER the foot. The most likely reason is that you have lowered them too much, or set it to 'embroidery'.
Page 50
https://www.manualslib.com/manual/969570/Pfaff-Creative-1471.html?page=50&term=Dropping+The+Feed+Dog&selected=1#manual
ManualsLib https://www.manualslib.com > ... > Creative 1471
View and Download Pfaff Creative 1471 instruction book online. Creative 1471 sewing machine pdf manual download.
Pfaff creative 1471 user manual (English - 76 pages)
Manuals.ca https://www.manuals.ca > Sewing machines > Pfaff
User manual. View the manual for the Pfaff creative 1471 here, for free. This manual comes under the category Sewing machines and has been rated by 5 people ...
I have a Pfaff 2140. Is the card reader a pcmcia type II?
The manual only refers to it as a 'Card 300'. I can find nothing online as to what the card actually is. It does say in the manual it has to be formatted inside the machine.
https://www.manualslib.com/manual/122000/Pfaff-Creative-2170.html?page=107#manual
https://www.google.com/search?q=pcmcia+type+II
https://www.google.com/search?q=pfaff+2140+card+types
My embroidery unit won't start in pfaff 7560 when hoop is in place
You should not place the hoop into the embroidery unit of the Creative 7560 until you see a prompt "Cover and insert frame 120" (or 80 if using the small hoop) on the LCD display. See https://www.manualslib.com/manual/504999/Pfaff-Creative-7560.html?page=91#manual . This allows the sewing machine to freely test/calibrate the embroidery unit. Other Pfaff machines, for example the Pfaff Creative 3.0, prompt you to remove the hoop and clear the embroidery unit area for it to do this step. (For this information see page 7:3 (75 of the PDF) of the Creative 3.0 manual: http://www.pfaff.com/SiteMedia/PFAFF/Products/Machines/creative-line/creative3_0/Manual/creative_3_0-manual-EN.pdf .)
I hope this helps.
1helpful
Can the presser foot be raised slightly on pfaff tiptronic 2030 to facilitate free motion quilting? There is not enough clearance with feed dogs down to freely move material to quilt. Thank you.
You need a special foot for free motion quilting--it is slightly shorter in height than a regular presser foot, which essentially provides space between the presser foot and the needle plate to manually move the fabric. Sometimes machines came with a standard darning foot accessory. Your Pfaff dealer probably has at least one style in stock. But there are other specialty feet you can probably use, ie Big Foot, clear free motion foot, C-shaped, oval, etc. You can also purchase a shank adapter (verify it is the correct shank for your machine) and use it with a kit of snap-on presser feet so you can have a variety of presser feet for different functions.
Pfaff Presser Feet
Pfaff Big Foot Free Motion Quilting Foot
Pfaff Free Motion Guide Presser Foot
Pfaff Free Motion Open Toe Quilting Foot
http://www.sewingpartsonline.com/snap-on-sewing-machine-presser-feet.aspx
1helpful
Why doesn't it communicate with my Pfaff 2140?
sounds like there not compatable, have you checked with pfaff technical support about the problem,
here's their number
Toll free assistance - 1.877.746.4375
here is a link for their support page
Machine Support
1helpful
Top sewing foot will not go all the way down
Pfaff creative 7570 Manual
https://www.manualowl.com/p/Pfaff/creative-7570/Manual/184474
Manuals and user guide free PDF downloads for Pfaff creative 7570.
Show me how to thread my creative 1473
Hello Shirley
Here is the link to a free manual
http://new.pfaff.com/SiteMedia/PFAFF/Products/Machines/Support-manuals/Creative_1473-manual-EN.pdf
and the instructions for threading and winding bobbin are on pages 14 and 15
Happy Stitching
1helpful
Top Sewing Machines Experts
SmartAviator
SmartAviator
Are you a Sewing Machine Expert? Answer questions, earn points and help others
