Power light is flashing amber, black screen
SOURCE: All dead except for flashing amber light.
You have a monitor with a common problem. After a few years some LCD monitors
will blow a power supply. The problem is caused by parts called
capacitors overheating in the confined space of he monitor. If you are
good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm
You can take the back cover off your monitor and look for the bad parts,
replace any that look like the pictures and your monitor should work
fine. The capacitors do need to be installed with the correct + and -
connections, note the stripe on the old one and insert the new one the
same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
SOURCE: Flashing amber power light with dark display
It sounds like you have a monitor with a common problem. After a few years some LCD monitors
capacitors overheating in the confined space of the monitor. If you are
good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work
Buddy
Corporate Computer
www.ccl-la.com
SOURCE: cant get monitor to turn on
try another monitor -
if it works - go into monitors and remove the drivers.
Re-install the monitor you are asking about.
If it doesn't work -- it has a problem - if it is LCD - you can get a new one or a good used one a lot cheaper then trying to fix the old one.
Best of it.
Rice
Testimonial: "cheers ill see what happens"
SOURCE: My HP Pavilion f1903 flat panel monitor had issues
tahandley144, NO EASY SOLUTION TO THIS!! I suggest you visit here first: http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ Do some reading, take a couple asprins and then make decision to DIY repair or just buy a new wide screen 2010 - 2011 unit. 12fixlouie
SOURCE: L1706 monitor power light flashes
A flashing
power light often means the monitor isn't getting a signal. When you
turn the monitor off and back on, do you see the brand logo for a
few seconds? Try plugging it into a different computer to see if it
comes on.
If plugging it into another computer doesn't work, it
may be a bad power circuit in the monitor. A common problem with
monitors is the capacitors going bad. If you're handy with a soldering
iron, you can try replacing them yourself. Look here for pictures and
instructions: Fix an LCD Monitor
