I dont know how to print with my clc copier through my computer
SOURCE: clc 1150 error 350
Normally only the canon service center will tel you what the error codes means. Suggest you call them .
SOURCE: HOW TO USE MY CANON CLC 1150
http://www.canon.fr/ Go to this location and see if they have a posting for manuals in french. You also may be able to purchase through ebay UK. Canon's help number is 1800okcanon they might be able to assist you as well.
SOURCE: Booting problems with Canon CLC 1150 Copier
The copier itself doesnt have a hard drive. Since you are talking about Fiery I assume you mean the colorpass RIP attached to the copier. A CD with the software on it actually came with the RIP but it was probably swiped by the dealer. In any case it needs a SCSI CDROM in order to load it. But all is not lost. The hard drive actually keeps a backup of the software on the hard drive itself. Kinda like a system restore partition on some computers. When you switch it on hold down the top right button until the diagnostics pass. then press "restore backup". this will take quite some time. Once it is done you will have to go back into setup mode and re-enter all the network settings. Dont forget the default paper size.
SOURCE: canon clc 1150
9 times out of ten that means you need a new drum when it does print does it look ok?? if yes then its definatly the drum it measures the voltage on the drum when its worn this code happens sorry
