Question about HP Officejet 6500 Wireless All-in-One InkJet Printer
Hp officejet 6500 e709n print quality poor even after replacing print head
Print quality poor even after changing print head and cleaning print cartridges
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • HP Expert
  • 307 Answers
For severe print quality/missing color issues there could be an air bubble/air gaps in the printer ink lines or a portion of the PRINTHEAD is dry, so you should first perform a Clean PrintHead procedure from your printer control panel.
NOTE: If one or more the colors were previously dry fired during printing (i.e. if you continued printing using only a few colors to one, air may have been accidently ingested into the ink lines between the cartridge(s) and PRINTHEAD. To recover from this problem, you may have to run the Clean Printhead procedure 2-3 times.
If a problem persists then it is suggested to review the steps outlined on the following HP 920 support pages, including printhead removal/printer cleaning and service station cleaning. It is suggested you refer to printer manufacturer instructions first as the Inkjet411 procedures are provided for general guidance purposes only. A dirty service station can cause poor image quality and/or ink cross-contamination between different colors:
http://inkjet411.retailinkjet.com/?page_id=1495
If the problem still cannot be corrected, then the PRINTHEAD may be dry and may need to be flushed (i.e. with warm water as it could have dried out, but this is a function of how much you print). Remove and soak in hot water for 5 minutes...thoroughly dry printhead prior to re-installing. Retest.
For more information please visit:
http://inkjet411.retailinkjet.com/?page_id=856
Worst case scenario the PRINTHEAD may simply be electrically damaged or at end-of-life (typically fails between 3,000 and 5,000 printed pages) and may require replacement, usually accompanied by error messages like Incompatible Printhead or Ink Delivery/System Failure. NOTE: The PRINTHEAD will eventually fail in time. For more information on the how the PRINTHEAD works, watch the video here: http://inkjet411.retailinkjet.com/?page_id=1983
To verify Printhead performance, run the Tap 41 diagnostic test, (Pen Status: Pen OK).....for printer model instructions please visit:
http://www.Inkjet411.com
Posted on May 24, 2013
6ya staff
SOURCE:
nalin_elliot
Nalin DSouza
  • 224 Answers
SOURCE: hP officejet wireless 6500 printer won't print
Yes I will tell you why Kodak photo paper is a little thicker in size and you should not get this same error message if you use hp photo paper or regular photo paper.See of this helps.....
Issue The Out of Paper message appears on the computer and the product stops picking up or feeding paper. Solution Step one: Reset the product
  1. Without turning the product off, remove the power cord from the back of the product.
  2. Wait 30 seconds and then plug the power cord into the back of the product.
  3. If the product is not already on, use the On button to turn it on.
Step two: Check the condition of the paper and reload it
  1. Replace any paper that is ripped, dusty, curled, wrinkled, or bent.
  2. Make sure that all the paper is the same size and type. Because only one type of paper can be used in the product at a time, paper types should never be mixed.
  3. Tap the stack of paper on a flat surface to align the edges.
  4. Make sure that the stack of paper to be loaded in the product contains no fewer than 10 and no more than 25 sheets of paper.
    NOTE: Do not load too much paper in the product.
  5. Insert the stack of paper into the product and gently push the paper guides snugly against the paper. Make sure that the paper is completely inserted into the product and can be picked up by the paper rollers.
  6. Try printing again. If the issue is not resolved, try loading different brands of paper and different types of paper, one type at a time, into the product and then try printing again.If the issue persists, continue with the next step.
Step three: Adjust the paper settings in the print driver The paper settings in the print driver must match the paper settings for at least one of the installed paper trays.
  1. Open a document in the program being used to print.
  2. Click File , click Print , and then click Properties . The product Properties dialog box appears.
  3. Click the Paper/Quality tab.
  4. Choose the appropriate paper size from the Size is drop-down menu.
  5. Choose the appropriate paper type from the Type is drop-down menu.
  6. Click OK and then click OK again to print the document..
  7. If the issue is not resolved, continue with the next step.
Step four: Clean the rollers
  1. Turn off the product and unplug the power cord.
  2. Open the access door to gain access to the rollers. Depending on the model, this is usually the rear access door. See the product user guide for information about locating the rollers.
  3. Clean the rubber rollers with a lint-free cloth, lightly moistened with water.
  4. Make sure that any paper rollers that rest on the input tray, which are located behind the back rollers, are cleaned. A clean cotton swab, lightly moistened with water, might be necessary to reach these rollers.
  5. Close the access door and plug in the power cord.
  6. Try printing again. If the issue is not resolved, continue to the next step.
Step five: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product. CauseAny of the following issues can cause the error message to appear:
  • The paper trays are empty or overloaded.
  • The paper is curled.
  • The print side, or shiny side, of the paper is not loaded in the input tray face down.
  • The paper might not be engaged with the feed rollers.
  • The paper-width guide is pressed against the paper stack too tightly.
  • The paper tray is not completely inserted into the product.
  • The paper settings in the print driver do not match the paper loaded in the paper tray.
  • The rubber paper-feed rollers are coated with dust.
Posted on Oct 03, 2009
Colin
  • 1584 Answers
SOURCE: My HP 6500 won't print blue.
Print test page in the software, if no blue try print head clean again, if no go return cartridge for replacement.
Is it genuine or refilled??
Posted on Jan 13, 2010
Paul Ronco
  • 5 Answers
SOURCE: HP OfficeJet 6110 Prints very slow then aborts about 1/3rd way through print
I identified this issue with my Officejet 6110xi All-in-One as firmware corruption. Attempting to install the supplied firmware update gave the error that "no hp device connected to the computer would benefit from it at this time." Attempted to power down the printer using #9 keystroke and got "FULL RESET" message, but problem of extremely slow printing and erratic behavior of the print heads persisted. I solved the problem by putting the printer outside in cold weather for two (2) days. This frequently resets firmwares with software corruption back to their embedded EEPROM state. Hooked the printer back up and worked fine. If cold weather is not available you could try other creative methods of cooling the device, just use a plastic bag and with ideally some drying packets thrown in to prevent excessive moisture buildup in the cold environment. The colder it is the faster the firmware resets.
-Paul Ronco, Computer Technician
www.paulronco.com
Posted on Jan 25, 2010
Mhinhi
Joel Tirado
  • 10 Answers
SOURCE: HP Officejet 6500 will not print after sleep mode
Move the printer to a different location and keep it closer to the connected device (e.g. router) and away from large metal objects / other electromagnetic devices for stronger signal strength.
Posted on Mar 01, 2010
puertobori
  • 7733 Answers
SOURCE: Office Jet 6500 E709n -
  1. Without turning off the product, disconnect the USB cable from the rear of the product.
    NOTE: The USB cable connects to the port on the back of the product. The port is labeled with the USB icon (c01424575.gif ). Figure 2: Example USB connection (your product might not look exactly the same as this example)c01651067.gif
  2. Remove the cartridges from the product.
  3. Wait for the 'Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
Solution two: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product.
If you need more help come back.Post / thumbs / testimonial are welcome!
Posted on Dec 04, 2010
How do you remove the print head for cleaning?
You should first try the cleaning procedure that is available through your printer's control panel - .HP Officejet 6600 6700 Printers Fixing Poor Print Quality Problems If that does not work here is a video on removing the HP print head.
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
May 10, 2016 | HP OfficeJet 6600 e-All-In-One Inkjet...
Not printing correct colors all come out light brown or pink
For severe HP OJ 6500/6500A/7000 print quality/missing color issues, or incorrect color output, there could be an air bubble in the ink cartridge(s), an air gap between cartridge and PRINTHEAD, or a portion of the PRINTHEAD is dry (quite common), so you should first perform a CLEAN PRINTHEAD procedure from your printer control panel.
It is first suggested you print the SELF TEST or PRINT QUALITY REPORT (under TOOLS menu) to aid in identifying which color is causing the issue. Check that cartridge or cartridges to ensure they have plenty of ink inside.
NOTE: If one or more the colors were previously dry fired during printing (i.e. if you continued printing using only a few colors to one, air may have been accidently ingested into the ink lines between the cartridge(s) and PRINTHEAD. To recover from this problem, you may have to run the CLEAN PRINTHEAD procedure 2-3 times.
If the problem still cannot be corrected, then the PRINTHEAD may be dry and may need to be flushed (i.e. with warm water as it could have dried out, but this is a function of how much you print). Remove and thoroughly flush all ink ports for 2-3 minutes...thoroughly dry printhead prior to re-installing. Retest. For complete instructions refer to video here: http://inkjet411.com/?page_id=2412
Worst case scenario the PRINTHEAD may simply be electrically damaged or at end-of-life (while Officejet 6500/6500/7000 printer PRINTHEADS are rated for an estimated 15,000 pages, the average consumer may only see up to a 10,000 printed page throughput) and may require replacement. A severe failure of the PRINTHEAD is typically accompanied by error messages such as INCOMPATIBLE PRINTHEAD, REPLACE PRINTHEAD or INK SYSTEM FAILURE. NOTE: The PRINTHEAD will eventually fail in time. For more information on the how the PRINTHEAD works, watch the video here: http://inkjet411.retailinkjet.com/?page_id=1983
To verify Printhead electrical performance, activate the Tap 41 diagnostic test, (i.e. Pen Status: Pen OK).....for printer model instructions please visit: http://inkjet411.com/?page_id=1813
To solve other HP920 ink-series printer/printing related issues please visit http://www.inkjet411.com
Apr 01, 2013 | HP Officejet 6500 Wireless All-in-One...
HP officejet 6500 does not dispense ink
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Nov 12, 2012 | HP Office Equipment & Supplies
HP 6500 wireless, having horizontal lines in photo printing
Perform nozzle clean, repeat this process twice or thrice check the print quality, if not satisfied replace print heads...
Jan 31, 2012 | HP Officejet 6500 Wireless All-in-One...
I have a HP Officejet printer model 6500 E709n (USB connected) and I have just changed the black print cartridge and now the printer only ptints blank ppages. I check of the printer status reveals that...
What about print head?.. perform print head cleaning process through tool box, check any back print out? no remove black/yellow print head clean nozzles manually, try it if not resolved replace print head..browse the link how to clean the print head..http://www.ehow.com/video_4974250_manually-clean-hp-inkjet-cartridge.html
Oct 27, 2011 | HP Officejet 6500 Wireless All-in-One...
The printer is not printing, ink is new
Ink means cartridges? but what about print heads?..go to tool box perform clean nozzles, check if not satisfied do this process twice or thrice. check print quality if you found yellow or black missed replace left print head, magenta or cyan missed replace right print head.. part number on print heads..
Sep 27, 2011 | HP Officejet 6500 Wireless All-in-One...
My HP Officejet 6500 Wireless printer won't print in black when trying to print from Microsoft Office Word and Microsoft Office Excel or PDF. The ink cartridge is new. I have turned the printer off and...
I also have the OfficeJet 6500 and had the same problem. The black text was printing using a mix of colored inks instead of the black ink, resulting in a grey, fuzzy text. I finally found a solution. In each application under Page Setup, there is an option called "Format for". Mine had been set to "Any Printer". I changed that to "Officejet 6500 E709n [830E4A]" and now it prints the black just fine. I have a Mac running 10.4.11. Hope this helps.
May 17, 2011 | HP Officejet 6500 Wireless All-in-One...
HP Officejet 6500 Will not print black. All ink if full, even replaced the black cartridge with new. Clean heads (via utility) 3 times. All other color cartridges (c,m,y) are printing. Work fine...
two actions I took that worked.
1) Remove the print cartridges. Raise the lever that holds the printer casing down (plastic square box), lift it up gently, remove it, and wipe with a clean, dry paper towel.
2) from the menu option on the printer. Go through the set up option and select "clean printer head" from the options. It will also do a self clean.
I did those two and it works nice.
Feb 08, 2011 | HP Officejet 6500 Wireless All-in-One...
Hp officejet 6500 wireless printer won't print quickbooks checks
go to control panel, printers, right click on my printer icon (HP Officejet 6500 E709n), click properties, click advanced tab and check "print directly to printer"
Nov 26, 2010 | HP Officejet 6500 Wireless All-in-One...
HP Officejet 6500 Wireless All-in-One InkJet Printer Logo
174 people viewed this question
Ekse
Thomas F. Schneider
