My microwave has stopped microwaving. It makes the noises and the plate goes round but no heat. The grill and the oven work fine. Any help appreciated.
Hi, I take it that this is a combi microwave? Some of these have settings on the front to microwave/grill/etc... so make sure its on the right one first!!
If you have selected the correct one then the m/wave does not work it could be several things!
Microwaves run to earth and need diodes to do this if these break down it will not m/wave! It could also be a internal fuse? ( but very unlikley if everything else works) Then you have the Mag or transformer which could be down to! M/waves run on a high power side and a low power side. The low power will not hurt you to much but the high power side will. My advice to uou is not to touch as it could be fatal as these things carry a high charge even when they are unplugged!
I have the same problem, and I have noticed that a papery type plate on the right hand inside wall of the oven appears to be damaged. I am assuming that this is something to do with the microwave no longer working, but would like advice if possible please before I shell out on a new oven.
