Hello, follow this link to download the manual and the codes for your remotes:
http://www.ofausa.com/remote.php?type=URC3220
just right click and save as on the download links.
if this does not work you can try the search method,
you do
this by either holding down the device button eg: TV or if you have one
the "magic" button for three seconds, a light should then flash twice
to say you have done this correctly.
then press the keys 991 then the power button.
you must now press the channel up key (ch+) possibly upto 150 times while the remote cycles through every code.
Once your tv or device switches off stop pressing the ch+ key and press the power button to make sure it switches back on,
(if you press ch+ too many times you can go back by pressing ch-)
When complete press the magic or device key again to save the settings (light should flash twice to confirm)
Many thanks
Mark
(www.sparky-uk.com)
SOURCE: need the code please
SEARCHING FOR YOUR CODE
If your device does not respond to the
remote control after trying all codes
listed for your brand, or if your brand is
not listed at all, try searching for your
code. For example, to search for a code
for your TV:
1. On the remote control, press TV once.
2. Press and hold SET until the LED
blinks twice, then release SET.
3. Enter 9 - 9 - 1.The LED will
blink twice.
4. Aim the remote control at the the
TV and slowly alternate between
pressing POWER and TV. Stop when
the TV turns off.
NOTE: In the search mode, the remote
control will send IR codes from its library
to the selected device, starting with the
most popular code first.
5. To lock in the code, press and hold
SET until the LED blinks twice, then
release SET.
6. To search for the codes of your other
devices, repeat steps 1 through 5, but
substitute the appropriate device key
for the device you are searching for.
I found this off a urc-4605 manual online but I think it works for all models worked for my urc4640b00
SOURCE: ONE FOR ALL URC-4640B01 REMOTE
on the remote press tv once press and hold set until the LED blinks twice then release set enter 9-9-1 The led will blink twice aim the remote control at the tv and slowly alternate between pressing power and tv stop when the tv turns off to lock the code press and hold set until the led blinks twice
SOURCE: i have the urc-4640B01 remote and i dont have the
These are the codes, I used for my Emerson TV's. 0002, 0294, 0479. Hope this helps you!
0154 0236 0463 0180 0282
0178 0019 0179 0177 0185
0623
OK.
