SOURCE: Hi I have 5 Juki DDL-8700-7 machines and I need to
So many machines you would be best at aution as one complete lot.
SOURCE: I need to change the
hi there
how come tere doesn't seem to be a tray under the machine ? pleasemake sur your machine come with oil pan ( could be come with oil pan ). or maybe your are talked about other model.
please follwo this steeps to change oil for your machine if it come with oil pan:
1 - back head of machine to back said.
2 - you will found oil pan and in right said you can see screw for empty old oil please put any bottel under oil pan and remove that screw until oil is come down .
3 - try to clean oil pan with any dry material and rethight the screw again.
4 - but new oil on oil pan until arrive to high level and turn ON you machine any running it for arround 10 minutes to make oil goes throw all tubes insaid machine.
best regards
ashraf abozid
CAIRO -EGYPT
SOURCE: my Juki 8700-7 top thread
hi there
please check timing cam for thread trimmer, need to re adjust again - check tension disk is open during trim or still close ( if closed always please check some parts missing from tension ) - check wire between tension and solenoid trimmer correct or no movement.
best regards
ASHRAF ABOZID
CAIRO - EGYPT
SOURCE: I have a brand new
Hi and welcome to FixYa, I am Kelly.
This is a self-oiling industrial sewing machine that uses a reservior in the bottom of the unit for lubrication. There is a sight gage on the lower left side of the unit in the base that once filled with oil you will see the oil splashing as the machine operates. Since this is a new machine you fill the lower reservoir to the High mark on the sight gage and then operate it a 3000 Rpm for 10 minutes to do the initial self lubrication. Instructions are in section 6 of the users manual. The main unit is tilted on the base to service the oil in the lower reservior. They don't bother telling you that once the unit base is installed in the sewing console that you should then fill it with oil before installing the main unit on the base.
This link should download your users manual so you can read it on the computer. See page 3:
http://www.google.com/url?q=http://www.juki.co.jp/industrial_j/download_j/manual_j/DDL8700/menu/pdf/instruction_eg.pdf&sa=U&ei=RP1KTqK8A6rkmAXgp9HvBw&ved=0CDUQFjAI&sig2=Tnu57Jl3GxY6Poevdo2WMg&usg=AFQjCNFzkTRDDqdrUjtV3b4zB91m43W8bg
Thanks for choosing FixYa,
Kelly
SOURCE: how solve Juki DDL 8700 automatic single needle
hi there,
1- check V belt if there's more loose plase make it tight littel.
2- check timming cam for thread trimmer , sometimes lock after trim and E7 appear.
please advice me type for control box ? i can give more help if you have basic knowledge for electronc. just email me if you want any time.
best regards
ashraf abozid
[email protected]
CAIRO - EGYPT
