I have changed the timing chain and tensioner one year ago only bt its sounds so irritating
SOURCE: 98 Saturn sc1 timing chain noise
need to have a shop fix it asap.if the chain breaks or skips timing your entire could possibly need to be replaced.replacing a serpentine belt tensioner is fairly cheap and easy
SOURCE: timing chain and tensioner noise/ replacment
release your tension on the tensioner pulley and spin it with your hand it should feel smooth when rolling any roughness and its bearings are bad
SOURCE: mazda cx7 engine noise
just get rid of this car, because you are going to need a new engine soon, my 2007 mazda cx7 with only 33000 miles is at the dealer for engine replacement!!!! only 2 days after i purchased the car
SOURCE: How do i change timing chain chain guide and
first of all take out tappet pan cover,turn engine clockwise until #1camshaft are closed(intake and exhaust lobe are opposite each other)on the crank shaft pulley there is a little cut it should line up on the front plate 0 if not the pulley damper is off just make sure #1 camshaft lobes are closed. now on the realease the two tensioner bolt on cylinder head (tensioner located above deisel pump on the cylinder head) take it out unbolt front plate pull sprocket out ,chain unbolt guide. now when putting back chain all slack to go on tensioner side .when you take the tensioner in your hand there is somthing holding back the teeth press with fingers and push the teeth inn hook it with hook now put on tensioner turn engine 1revulusion to see spining free
