Check the amps that are being drawn by the headlights. Compare that with what the bulb should be drawing using: amps= watts / volts I am going to guess its higher but not to the point of blowing the fuse for your lights. I would then start checking grounds. Or, you used halogen bulbs and you touched the glass. I doubt they would both fail at the same time from that.
When the same bulb burns out often,it is usually vibration that does it.When driving at night is that headlight a steady light on the road or a shaky light?
Is that headlight assembly tightly mounted and the bulb secure in the housing?
Appereantly headlight on the Kia do not last long, I have lost count of headlamp replacements. Basically, I would say that they last about 5-6 months or less, and we don't do a lot of driving. We have learned to turn off our headlights during the day to minimize run time and on/off surges. We have already had to deal with one fix-it ticket and we are constantly worried about getting pulled over because one of the headlights could blow at any moment. I buy headlights in two packs now to save money. Before you change the headlights check the fuses, in both fuse boxes for any blown fuses, One is under the hood to your right side beneath a black case I beleive, and the other is in the car, near the drivers left leg on the wall.
ive had 2 camaros and both did this. remove the headlight and take the bulb out of the back of the sealed beam. be careful not to break it as its glued in, but it is possible. just be gentle and patient. replace the bulb with an aftermarket 9006 bulb (hi beams are 9005) and silicone it back into the housing. i haven't had one burn out yet after doing this
