How to change from fahrenheit to celsius
Press both up and down buttons for 5 seconds
Release
press both up ans down buttons for 5 seconds again
Release
14 and ? small 0 will appear. Z?ro is for farenheit.
Use th? up arrow to change the 0 to 1 for celcius
SOURCE: How do I change my Honeywell FocusPRO6000
Press and hold the up arrow and fan buttons until the display changes. Then press Next until you see 14 in the display. Change this value to 1 (with the up and down arrows) to get Celsius. (O is Fahrenheit.) Press Done to exit and save the setting.
The manual is available here: http://customer.honeywell.com/Honeywell/ProductInfo.aspx/TH6110D1005 . Scroll to the bottom and choose a manual then press Download. This particular section is in the Installer's Guide.
I hope this helps.
SOURCE: temp dispayed in celsius.
Inside the thermostat (behind) are 3 tiny DIP switches.Switch #3 should be set to OFF or click it to the left to display *F.You can use a tiny scerwdriver
If your temperature reads in climate control reads in degrees Celsius "C" instead of Fahrenheit "F", follow these steps to change to Fahrenheit.
The display should then change to "F". Follow these same steps to change your read-out to Celsius , if preferred.
