Megatronix - TW71 - 5 Button 2 Way LCD Motorcycle Transmitter Remote Replac Logo
navil avila Posted on Sep 25, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Autopage xt74 alarm in silent mode
My car alarm is in silent mode-i believe- the car used to chirp when locking, unlocking, and now it doesnt... how can I make it chirp again, not the pager, but the actual car
Larry Spears
Level 3:
  • Autopage Master 625 Answers
  • Posted on Sep 28, 2012
Larry Spears
Autopage Master
Level 3:
Answers
625
Questions
0
Helped
378095
Points
1510
The only reason that your alarm would not chirp when locking and unlocking the doors is that the system is in valet. A visual notification that the alarm is in valet mode is the LED light is on solid. If the LED is on solid and you wish to make the alarm active again, turn the ignition on then, press and hold the valet/programming switch for two seconds. The LED light will turn off.
If the LED light is not on solid then, the issue may be with siren itself.
3 Related Answers
Anonymous
  • Posted on Jun 01, 2009
SOURCE: how do i use autopage xt42-lcd
new baterie
Anonymous
  • 7 Answers
  • Posted on Jul 16, 2010
SOURCE: i have the normal alarm Autopage AutoPage C3RS603
Nothing is hard to hookup just time consuming andf it all depends on how good you R with wiring how good R you..?
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Sep 11, 2009
SOURCE: where is the relay system on a car alarm
it is a standard bosch style relay, it should be under the dash on left or right of the steering cloumn
2answers
My viper 5701 alarm is having issues.
First thing is to trip the system to see if the siren works then. If it does, then perhaps you inadvertently set the chirp commands to silent. If the siren doesn't work when the system is tripped then that's your problem. You'll need to find the siren and troubleshoot possible causes. I'd start with the wiring but the siren could have simply gone bad. You should be able to test it easily with a test light or multi-meter.
RS855LCD 2-way remote and key fob dreain batteries
I see this is a old post but, I have this unit in a used van that came with no remotes. A local audio shop paired it up with a AUTOPAGE XT-33. I can lock,unlock,start with this remote. Just remember to keep the drivers open while doing these steps.
1. Turn the Ignition 'switch 'OFF/ON' 3 TIMES and stay in
ON position. Within 15 seconds.
2. Push the Valet switch 2 times and hold in on the2ndpush, when a long chirp is heard then release the valet
switch. You are now in the Transmitter programming mode.
Program:1. Press the Lock button on transmitter 1 until the siren
responds on Car with a confirming chirp; the first
transmitter is now programmed to Car.
Exit: Turn Ignition to 'OFF' position, or leave it for 15
seconds. 3 long chirps will confirm exit.
Note: If more than 4 transmitters programmed, the system
will only keep the last four.
The Valet switch is a little Red Push Button that should be
mounted under the lower left side of you dash or in the lower
left kick panel near the E-brake pedal.
I have the autopage cs rs 665 alarm system installed on my 95 chevy caprice classic. Ive had it installed onto my car a little more than a couple of months ago and then like a week or two ago the whole...
for heavy machinery cars etc. luckily there are many websites
that can help you repair
for eg site like reliable-store is very active in this.. instant help, emails and all that's fantastic
tried and tested !
Car alarm not chirping when armed. I hit the lock/unlock button on the alarm remote and I can hear the doors lock/unlock but there is no noise.
u might have a button sequence that makes it silent u need instruction manual , to see what buttons to push
Where is the relay system on a car alarm
1helpful
Starter vallet reset
I think I know what you are talking about. I am unsure what alarm you are using but on mine I have a two button remote and if I push button one briefly than button two briefly then one again it will either enter or exit the silent mode.
Good luck !!!!
2helpful
Need to Silence Python Car Alarm 'Chirps' Permanently
I had the same problem, then I downloaded the user manual from the Directed Electronics site. It seems with most of the remotes (1400xp included) all you have to do is press the AUX button and then the Lock/Unlock button. This puts it into Silent Mode and no more chirping late at night or early in the morning, but you still have the ability to have it chirp when you need to by only pressing the Lock/Unlock button. Hope that helps.
Does not cherp
Is your perhaps alarm in "valet mode"? I've got a Checkmate on my Honda, and I can turn valet mode on/off by putting the key to Accessory, then pushing the black button under the left of the steering wheel. The alarm chirps when you switch the mode.
Top Autopage Vehicle Parts & Accessories Experts
John
John
Kardoc
Are you an Autopage Vehicle Part and Accessory Expert? Answer questions, earn points and help others
