Kenmore 13.7 cu. ft. / 388 liter Upright Freezer 23424 Logo
eddie muse Posted on Sep 24, 2012
Where can i buy freon from? - Kenmore 13.7 cu. ft. / 388 liter Upright Freezer 23424
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Sep 24, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
332
Points
19
Freon can no longer be purchased by the general public. You will have to call a repair person.
ISN'T GETTING COLD NEED TO KNOW HOW TO ADD FREON PLEASE ?
Unless you have a lot of expensive refrigeration tools and a license to recover and buy freon, then you need a serviceman.
My Magic Chef chest freezer stopped cooling, slowly, over two weeks. I emptied, unplugged, defrosted, cleaned coils, and powered up again. Red light is on, won't cool. Guessing freon or compressor...
Sounds like slow Freon leak. You might get an estimate over the phone before calling a technician, but I would think a 3-year old box is worth repairing. If the estimate is close to the replacement cost, that might not be the case.
2answers
Small freon leak, food safety
fixing freon leak. Evaporator is leaking freon. Replaced Evaporator on this video
Sep 23, 2009 • GE Freezers
Frigidaire stand up frost proof w/ temp alarm / 98' model. Compressor running, no power problem. Removed interior panel and found that evaporator coils not getting cool. When switch for alarm is pushed on...
If your compressor is running with no freon, It should be very hot. Check if it is. And if it is and the freon has leaked out. Then you must find the leak in the system before you add more freon. If you dont this will be an ongoing problem. The freon will leak out after any length of time. This is a very hard task to find the leak, and you will be money ahead to buy another if you dont find the leak than to re charge every year or so.
Punctured freon line in freezer
Please don't rate me down for this answer, but I'll be honest with you. No, you can not fix it yourself. The entire evaporator would have to be replaced by a service tech who has a refrigerant certification and the proper tools to do it. It would be prohibitively expensive. It's time to buy a replacement.
Upright Freezer not freezing,
looks like low on freon. that causes freeze up. oddly enough they freeze up when charge is low , just the opposite of what you think they would do. you have a freon leak unfortunately. probably not accessible, and therefore not repairable. i would suggest, cut your losses and buy new. unfortunately for me and all other srevice techs, the days of affordable repair are over, you can now replace cheaper than i can fix and have a warranty and its new... good luck
Rack on freezer is not working
low on freon. buy new . as freon level drops , ability to feed all shelves falls off. the last shelf to freeze is usually the first one to not freeze ,as charge goes away. time for new, cost to fix to great.
Candy fridge freezer
It sounds like a Freon leak. The compressor is running and it gets a little cold. THis is not something you can fix yourself. You have to have certification to buy freon and gauges and know exactly how to use them. Besides in most cases you can't find the leak and will have to keep recharging it.
Jun 28, 2008 • Freezers
Not freezing
Freon leak. Needs charged. You can't do this yourself as you have to be certified to buy freon.
Freezing
YOU COULD GO TO THE AUTO ZONE AND BUY A TAP VALVE AND FREON 134A CHARGE IT THROUGH THE LOW SIDE SHOULD READ 5 AND HIGH 150 USE 134A. IT MIGHT WORK FOR A FEW MONTHS TO A YEAR IF NOT LONGER BUT YES IT HAS A LEAK THE CONDENSOR IS BUILTIN AND MADE OUT OF STEEL AND IT RUST THROUGH OUT THE YEARS THEY SHOULD OF USED COPPER NOT STEEL
Top Kenmore Freezers Experts
Jay Finke
Jay Finke
ZJ Limited
ZJ Limited
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
