Question about Sharp XR-11XC Multimedia Projector
Over heated won't respond to outlet
There was a thin scarf over one side of the fans while I was watching a movie and the projector overheated and would not respond to outlets. A few days later after it cooled it still won't respond to being plugged in.
4 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 36 Answers
SOURCE: I was using my SHarp xg e1000u projector today and
may be a loose electrical connection inside may need to send it to a shop to be fixed
Posted on Aug 01, 2009
John Cunningham
  • 6771 Answers
SOURCE: Sharp Carousel R-7A85 Won't Turn On
Yes! but the fuse went for a reason, the problem could be a bad door switch to a more serious problem.
Posted on May 30, 2012
rgall3285
ray gallant
  • 65423 Answers
SOURCE: do you offer repair support for lcd tv`s
sorry we do not repair anything
Posted on Jan 24, 2015
Testimonial: "I did not ask you to repair anything. I ask for any support knowledge smart a--"
Optoma movie time projector has a vibrating sound
Normally this sound noise is the small FAN inside. Dirty or faulty. You must open the proyector, or go to some shop repair.
God bless you
Jan 25, 2013 | Optoma EP706 Projector Remote Control
Acer Aspire 4930 heats up very quickly
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Mar 28, 2012 | Acer Aspire 4930-6862 Laptop
I have HPG60 with AMD Turion X2. During viewing of DVD movies or movies stored in C the battery and its compartment gets heatedup after say 20 minutes or so . the same thin happens during video chat
You may have a faulty battery or a CPU fan problem.
Mar 12, 2012 | HP G60-120US Laptop
My projector won't turn on, only the power light shows red, the status light is blank. Tried the remote and manually turning it on.
Hello
If the power light is ON and status light is OFF; check if any objects are blocking the air inlet or outlet grill, and remove them if any, and carry out the following.
[1] Unplug the power cord from wall outlet.
[2] Make sure that the projector has cooled off.
[3] Plug the power cord into the wall socket.
[4] Press the power button.
Check whether the cooling fan has stopped. The problem is with overheating itself.
If these does not help you, your projector need service. OK.
Nov 18, 2011 | Mitsubishi HC1500 DLP Projector
Epson PowerLite 410W projector (used for a smart board in a classroom) won't project anything or even turn on. Power button (maybe lamp indicator light? I don't really know anything about this...)...
It seems you assume that it is not an overheating problem.
The problem is, the bulb gets really, really hot when using the projector. It doesn't matter whether it has been there without any usage. As you switch it on, it will start to get hot.
But the lamp or other parts of the projector should not get too hot. To control the temperature, air is moved through the projector with the help of fans. Air enters through air filters and move through the projector absorbing heat from hot parts. This prevents these parts from getting overheated.
But what if air doesn't flow freely? Then the parts CAN get overheated.
First, switch on the projector and check whether you can hear the fans working.
Next, switch off the projector and remove power cable.
After about 30 minutes, remove the cover and check whether the air filters are blocked. If they are, clean them with a small brush.
This would probably solve your problem.
Sep 23, 2011 | Epson PowerLite 410W LCD Projector
Plugged in and turned on automatically said it overheated won't turn on or off
you fan could be bad and needs replaced try putting a a small fan next to the excaust vents than see if dies the same thing, if it does it could be than the fan needs to be replaced or the thermal sensor needs to be replaced. hope this helps
Jun 04, 2011 | Optoma DV11 Projector
When you are watching on projector sanyo PLV-Z2 it goes off and
overheating. possible fan malfunction. clean out the projector with canned air. dust keeps in the heat.
Oct 24, 2009 | Sanyo PLV-Z2 Multimedia Projector
VPL-HS20 shuts down in the middle of a movie
There is a heat sensor cutting down the power. The sensor is located on the upper side between lamp and fan and is monitoring the air temperatur. I don't know what is causing the sensor to switch - excessive heat or simply age or ... . Anyway un screwed this sensor and my problem disappeared.
Possibly a stronger fan would solve the problem too.
Jun 26, 2008 | Sony VPL-HS20 Multimedia Projector
Cinego Automatically shutts off after 15 seconds
had the same problem - replaced the lamp even though it only had 632 hours on it. seemed to fix the problem - 10 hours and 4 moves later still doing ok
Jun 12, 2007 | Radio Shack Cinego D-1000 Multimedia...
23 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
amir hamza
amir hamza
k24674
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
