The screen goes blank on a certain angle - Apple aluminum 13-inch MacBook laptop- Intel 2.1GHz l Core 2 Duo, 1GB 667MHz DDR2 SDRAM, 320 GB HD, ... Mac Notebook
There could be a few potential causes for this issue. Some possibilities include a damaged or malfunctioning camera lens, a problem with the camera's sensor, or an issue with the camera's firmware or software. To troubleshoot the problem, you should first try restarting the camera and checking to make sure that it is fully charged. If that doesn't work, you may need to take the camera in for repair or contact the manufacturer for further assistance. It's also possible that your viewfinder is dirty, which can cause black or blank spots on the screen. Clean it with a microfiber cloth or a soft brush, being careful not to scratch the surface
Have you checked monitor settings Carl? Some are set to sleep after a certain period of time. Mine was set to sleep after 1 hour (unknown to me) until I reset it. =)
Ok ! So try one thing remove HDD from the laptop and then start the laptop.And i am sure that u will see that the screen gone black at certain points. So dude its LCD problem . Go to nearest Laptop repairing center and he can change your LCD. then it working properly
Hi, first of all check your AVI cord by changing it or check your settings if it's set on timing off at certain intervals. then after all said and done format your system.
Try your monitor on another computer, just to make sure it's the monitor and not a video adapter problem in the computer. It may be possible to fix it if you can find a reliable computer or TV service shop nearby. However, the cost may not be worth it for a 2-year old monitor. Unfortunately, the best solution is probably to buy a new one. : (
