Question about Safe International Digital Electronic Safe Lockbox Gun Jewelry Lock Box Tool
Safe S - 25EY, Serial number 01/05
Http://www.youtube.com/watch?v=eOdmMb90YEE
I may be late but I hope it helps, the safe is easy to break into if you use this technique
Posted on Nov 20, 2012
If the numbers are not on the front of the lock and there is no serial number to give to the company to get the key made then the next best thing to do is to take the safe down to your local locksmith shop and have then fit a key to it.
chris...
Posted on Sep 27, 2012
Unfortunately the safe is bolted to the floor. But I will ask if a locksmith can come and fit a key for it. Thank you for your suggestion.
a locksmith for sure will be able to come out to you ~~ there will be a service charge for the trip but you will end up with a set of keys for your safe. chris...
SOURCE: I cannot open safe with the usual code.Safeguard electronic digit
To open a Safe International Digital Electronic Safe
User override key to open safe
Then:
a. Inside the open door you would find hidden a red button press this button, the yellow light will be on, input the user code in 30 seconds try 1,5,9 then press A or B to finish
b. If the yellow light keeps flashing with beeps the code is wrong( revere to user manual)
c. To change code repeat step a.
Test your new code before closing safe.
Posted on Apr 27, 2009
SOURCE: need to reset the electronic code to open the safe.
are you the manager user of the safe?if yes,you can reset a new code by yourself.
Posted on Apr 09, 2009
SOURCE: BATTERIES FLAT CANNOT OPEN MICROMARK SAFE WITH KEY
http://www.rotteneggs.com/r3/show/se/198433.html
:D x
Posted on Jun 02, 2009
SOURCE: i have a gordon digital electronic safe # P45891,
Take the single screw off of the entry pad and remove the cover plate. Using the key that came with the safe, unlock the safe. Now, look for a little red button on the inner hinge. Push it in and you will note the yellow led on the the front of the safe turns on. Now, enter a 4 digit code of you choice. This is automatically saved and is the new 4 digit code you press to open the safe.
Posted on Jul 15, 2009
SOURCE: i forgot the safewell electronic code and didnt have the key
NOTE: The safe needs to be upright and right side up or the locking mechanism
won’t work.
ELECTRONIC SAFES
To open an electronic safe the first time, press the following numbers/letters on the
electronic keypad –159B. (These numbers are preset. You should change the code as soon
as possible after opening the safe to insure proper security). After you have entered the
factory set code, you will need to turn the knob on the faceplate to open the door. You will
have 5 seconds to turn the knob before the locking mechanism is reactivated.
ENTERING YOUR SECURITY CODE
To enter your own security code you will need to follow the steps listed below:
1. After opening the electronic safe (with the pre -set factory code of 159B) locate the
small red button on the inside of the door near the hinge.
2. Press the red button and then release it, you will hear a beep.
DO NOT SHUT THE DOOR UNTIL YOU HAVE CONFIRMED THAT YOUR NEW
SECURITY CODE HAS BEEN ENTERED CORRECTLY.
3. With the door open, enter your own personal security code, which can be 3- 8 digits
long, and confirm your new code by pressing the letter “B” on the electronic touch pad.
Before you close the door, try the new security code to make sure the lock release the
knob so you can turn it and retract the live action locking bolts.
If you can not get this open more then likely you will have to cut it open.. One last thing to try is to email safewell
sales@safewellsafe.com
Good luck
Posted on Sep 14, 2009
Jan 10, 2016 | Home Security
Apr 06, 2013 | Safe International Digital Electronic Safe...
Jan 26, 2011 | Safe International Digital Electronic Safe...
Jan 03, 2011 | Safe International Digital Electronic Safe...
Jul 25, 2010 | Safe International Digital Electronic Safe...
Feb 24, 2010 | Safe International Digital Electronic Safe...
Feb 19, 2010 | Sentry Fireproof Safe
Sep 18, 2009 | Kitchen Appliances - Others
Jul 24, 2009 | Safe International Digital Electronic Safe...
Apr 27, 2009 | Safe International Digital Electronic Safe...
2,338 people viewed this question
since this post i have been able to reset the safe. I still don't have the safe key and can't seem to locate it on the key hole area. does anyone know where the 3 digit number can be located...so I can order a new key?
