The heat pump go on by 5 seconds the breaker in position off (50 amp) wire no 10 the heat pump run very little time and next the control is in off position
SOURCE: Can't shut down the main
The relay is probably bad. If you open up the main outdoor panel, you can watch the bottom of the relay for the pump, ususally on the upper left of the relay cluster (black). Watch for a small tab popping out when turning on/off. If you don't see it, the relay is bad. This assumes you hear a click when doing this.
SOURCE: Jandy Aqualink RSO301 keeps blowing fuse
Great discovery! You're welcome.
Could you please take a few and rate my assistance.
thanks...
Charlie
SOURCE: We have an AquaLink RS4 All Button control in the
can't be made the only is to cancel the delay on the back dip #4 heater cool down turn off breaker when do this also change assign jva at system setup
SOURCE: I have Jandy RS4 system with 4-button poolside
Pull the cover off the control panel. You will probably find a button which would be accessible from outside the panel with a paper clip or pencil but is unlabeled. On the board itself by the button, in small letters it should say "reset". Push the button and see what happens.
