I have a Onkyo HT-5100 HTIB. It has 3 hdmi inputs, 1 hdmi output(passthrough only). I have a Sony Blu-Ray DVD player connected using hdmi input 1, DishNetwork HD DVR Satellite receiver connected to hdmi input 2, and a Toshiba Satellite X205 notebook connected via hdmi input 3. I have the hdmi output to my TV, a Toshiba 57" DLP.
My question is what is the optimal way to configure the audio with this setup? Can I use an optical audio cable as an output from my TV back to my audio receiver? I've thought this would work but have had no success so far. I've had to use components cables to get audio. There has to be a better way to consolidate the audio back into the HTIB. Don't get me wrong, it sounds pretty good now but I'm sure there are some tweaks that could make it even better, and some better ways to get audio, especially from the Blu-Ray player.
Thanks!
You can't just plug in optical cables. Both the TV and amp have to be adjusted to allow the different type of signals to pass. I have an Onkyo receiver myself and you have to set the sound type up for each input. It's a bit tricky to do without a manual, but you can probably download one for free if you have lost yours.
SOURCE: Onkyo HT-SR750
Check out Onkyo's website: The HT-SR 800 description says "a separate audio connection is necessary" Maybe it is true for the --750 too.
SOURCE: Onkyo TX-SR605 conected to Mitsubishi DLP TV
What I think I did and how I fixed it!
FACTORY RESET ON EVERYTHING!
All you have to do is to do a factory reset on everything, but I thing mostly on your 605, but I would do it on the TV as well. I think what had happened is after I set everything up for the first time, it worked great. As the days when on I started to play with all of the futures the 605 and the TV had to offer. I was turning them on and off to see what everything did. What I think I did was, I turned on something in the 605 that the TV did not know how to cope with. If I had to guess, I think it is the Lip-sink feature (Spelling?) in the 605.
Anyway disconnect everything, look in your manuals of the TV and the 605 to see how to do the factory reset on both. Then turn your TV on. After it does it’s start up for the first time (again), start connecting the 605.
It has been working great for me after I did this. Do not count on help from the people you bought it from or the people who made it. This stuff is so new they do not really know how to fix it.
Robert…
SOURCE: Dvd connection
Yes! You can pass the video signal through the receiver. This is most useful when you have more than one video device (e.g. DVD, cable box, VCR,...), and you can use the receiver to switch to the audio and video for the selected source at the same time.
On the back of your Onkyo HT-SR800 there is a section labeled "Component Video." It has three inputs and one output. So, attach your DVD by component cables to the "DVD In" and then attach component cables from the "OUT" receiver connection to the TV.
If your TV doesn't have a component connection, then this addresses your other question. You can't gain anything with this, because your TV doesn't support it. Connect the DVD to the TV according to the highest quality connection that they both support, in this order: composite, S-Video, component.
If you are using composite, but they both handle composite, than yes, you will get a better picture by going to component (or even S-Video). If both devices support progressive scan, this could be a substantial difference.
Your receiver accepts component, s-video and component video, but keep in mind, it may not do "video switching." So if you connect the DVD in via component, but go out to the TV over composite, then you may not get any video at all (but feel free to try). Try to avoid this, but you may be forced to try depending on the limitations of the various devices that you are hooking up.
SOURCE: DVD signal received in wrong aspect
PRESS SETUP GO TO MISCELLANEOUS PRESS ENTER THEN DOWN TO OSD SETUP PRESS ENTER AGAIN AND DOWN TO MONITOR AND CHANGE TO 16.9.
HOPE THIS HELPS.
CABLE GUY.
SOURCE: connecting blu ray to surround sound receiver to tv
Hi, I have just completed this installation myself.
You are correct, HDMI to Amp Input from Bluray and then HDMI from Amp output to TV. Coloured cables are not required to operate the bluray now.
Good luck
I've now got the optical cables ran from both the Blu Ray and the DVR rec. as you suggested and it's working.They are both supplying audio now. I'm now able to eliminate all the RCA cables except the ones for my laptop since it doesn't have an optical or audio coaxial connection. I'm still convinced there's a way to get audio output back from my TV to the receiver.
Okay, found out that the optical out from my TV will send audio back to the audio receiver. Instead of using the remote to assign connections like for the HDMI and Components, you have to configure it on the front of the unit. I now have 3 HDMI inputs, 1 HDMI output, and 1 optical input.
I read thru nitemedic9's string.....this is good news to know that the sound can be fed back to my receiver thru a fiber optic cable. I have read hear that this needs to be set up on the front of the receiver, rather than using the remote. I still don't understand how to get this to work! Could this be explained in a little more detail please?
Manual says that HDMI audio is only passed through to HDMI output, and is not tapped by the speakers at all. Each of the inputs needs a non-HDMI audio connection.
The Blu-Ray player should have a digital audio out, and maybe the satellite receiver too.
