Think it the first generation of this model at least 8 years old
If the bearing are going it will sound like a plain taking off grinding banging them you will end up with grease all over your clothes was told from an engineer once never put you m/c on any thing over 900 rpm spin speed as the bearings ar not designed to go any faster i have a hotpoint and its over 12 year old still sounds like new and never had a problem with it hope this help
SOURCE: LG Tromm WM2277HW will not spin both directions, LE error.
Short answer: The post+images by “chem-prof” on Jan 10, 2008 and the post with part instruction by “wolfster” on Dec 04, 2007 solved the problem!!! You guys are the best!!!
Long answer: We purchased the LG WM2277HW three and a half years ago. We have been VERY happy with the results. Last Thursday we got the LE error code after placing a single sofa cover in for a quick cycle. I’m not sure if this is what caused the part to go bad or it’s just the fact that this part might have a “time limit” so LG can make more money on service… (sounds like my Volvo!!!). Anyways, after freaking out for five very long minutes, I Googled the phrase “LG Tromm WM2277HW will not spin” and got directly to this page (WAHOO, FixYa.com!!! You guys are great too!!!). Read the instructions posted by “chem-prof” and “wolfster”. Following “wolfster” I went to download the user manual and exploded diagram from http://136.166.4.200/contents/Laundry/WM2277.htm, then I went to http://www.mcminone.com/ and typed “P/N 6501KW2002A” in the search. Got the “sensor assembly” part for $17.50 + $22.50 (2nd day air UPS). Make sure to note “Please send me a UPS tracking info” in the comments field. Got the UPS tracing e-mail from mcminone.com and waited…. Tuesday was my delivery day (Ohio to Florida). On 5pm got the part by UPS. At 5:15pm it was all assembled and first cycle was started to run!!! Now it’s my 3rd cycle and the baby LG WM2277HW is spinning like usual!!!
OK, now let me tell you, the images by chem-prof are great, but I found that if you take the three screws that attach the electric cords to the drambase it will actually make your life easier and it you will not need to disconnect one of the cords/plug, only the small one that attaches to the “sensor assembly”. See my image for the process:
A. Take off the 4 screws for the metal covering
B. Take center large screw (#2 on my list, it was a mistake…), this will not be as easy unless you have someone else to hold the dram from the front… but it’s doable after all, I did it!
C. Take off the magnets covering, this may require some shifting left and right, while pulling to the back (placing it back is not that easy, indeed watch your fingers when placing it back!)
D. Disconnect the cords attachment screws (#1 on my list)
E. Take the 6 screws of the motor (looks like a circle with orange cords around it!) (#3) and place the motor on a towel on the floor
F. Take off the plastic part (“sensor assembly”) from the motor
G. Place the new plastic part (“sensor assembly”) on the motor
-- Redo steps E to A backwards… voualla! You’re done!
H. Take your wife and the kids to a fancy restaurant for all the $$$ you saved!
SOURCE: lg tromm front load dryer dlg5988w
dryer has two fuses check both circuit breakers one is for heating the other is for the plug this fixed my front load lg this gives you the heat that you need to dry your clothes
SOURCE: LG Tromm model WM2455HW front loader walks and
It should have adjustable feet with rubber pads to prevent it from walking.
SOURCE: LG Tromm wm 1814cw makes loud noise
You will need to remove the back cover plate of the machine and locate the large pulley at the end of the drum. Remove the belt, then the pulley and you should see a bearing housing. Some models require a bearing and housing replacement, while others can simply be repaired with a bearing replacement alone.
Go here, and find the nearest Dealer for your part.
http://www.1stsourceparts.com/contact_us/branch_info.asp
Or you can try ordering direct from LG. If you are as handy with tools as you say, this should be a fairly easy job.
SOURCE: I have an LG Tromm washer. I start it up it start
LE code stands for locked motor error. When this error code appears in your front load washer it indicates a fault in the motor unit.
1 . Check the connections to the Coil/Stator at the rear of the unit possibly it should be something like a broken wire.
2 . Coil/Stator Assembly will be defective preventing the drive to operate.You should go for a replacement of that assembly.
Thank you !!
