SOURCE: piece of staple stuck in the trigger section of arrow t-50p
First, remove the magazine pusher / spring and any staples loaded in the magazine. Then try firing the gun to clear the staple. Use a small jeweler's screwdriver and small needle nose pliers to get the staple out. Reload and test. These are relatively inexpensive staple guns. If the problem persists it might be less trouble to replace the gun. Best of luck and I hope this solution works for you. Michael Mittelsdorf
SOURCE: My T50M Staple strips break up in the gun and jam
The staples are held together with an epoxy. I have used staples that are older than 10 years. The problem is the gun. Check for dirt or a burk in the magazine as well as a bent pusher blade. My gun also had a problem loosing a screw and nut that attached at the blade guide.
SOURCE: How do I load the staples in this staple gun?
Push in and down the silver color piece at the end of the gun. Pull piece and spring out. Load staples, end down. Reassemble.
SOURCE: How do I refill a n Arrow heavy-duty staple gun?
Fixed the old-fashioned way. Went down to the hardware store and got the demonstration. Thanks.
SOURCE: staples are stuck inside the stapler and will not come out
Typically you do not open these up.
Makes it difficult to remove stuck or wrong staples.
I have had good luck removing the staple ram rod and rapping firmly on the **** of the stapler against a wooden table. The idea is jolting the stuck staples into reverse out the way they went in. Tedious process but usually works. Removing the jammed staples in the nose at the striker plate requires using needle nose pliers and a sharp awl or small screw driver used on very small screws.
My T50 Arrow stapler is over 20 years old.
Still works great. Sometimes I slide in the wrong size staples by mistake. The process above usually works.
