Mustek Be@rPaw 1200CS Flatbed Scanner Logo
A
Anonymous Posted on Sep 22, 2012
Drivers for win 7 64 bit for scanner USB Mustek Be@r Paw 2448 CU Pro
5 Related Answers
Silverdragon
electronic & computer repair& servicre
  • 12061 Answers
  • Posted on Aug 03, 2007
SOURCE: mustek be@r paw 1200 ta flatbed scanner
OK i found it here Drivers Manual the lot.. http://72.14.253.104/search?q=cache:RAOfVBsN4hEJ:www.driverstock.com/Mustek-BearPaw-1200-driver-download/31-7-9031/index.html+Mustek+bear+paw+1200+manual+download&hl=en&ct=clnk&cd=3&gl=nz
Anonymous
  • Posted on Feb 19, 2008
SOURCE: Mustek 1200 UB Flat bed scanner
SELAM BENDE MUSTEK 1200 UB VAR XP NASIL çALIŞTIRA BİLİRİM XP DOSYAYI YüKLEDİM AMA çALIŞMIYOR 98 çALIŞIYOR YARDİMCI OLURSANIZ SEVİNİRİM TŞKLER [email protected] teşekkürler
Anonymous
  • Posted on Mar 02, 2008
SOURCE: mustek a3 usb 1200 pro scanner problem
I bought one a couple of years ago. After plenty of hit-miss after trying to get it to work on my fresh XP installations, I have a solution. Installing it the normal way simply doesn't work.
First, go to 'start', 'control panel' then 'system'. Click the 'hardware tab' then press 'device manager'. You'll see a list of hardware.
If your scanner is already plugged in, find it (it could be listed under 'imaging' or under 'other devices'. You should see a yellow exclamation point indicating it's there but not working.
If you go to 'control panel... system' first, and then plug in your scanner, it will pop up automatically.
Now, right click on it, select 'update driver'. A window pops up. Insert the CD, then select 'have disk' and install normally.
Installing the remaining software is optional (acrobat 4.05 and so on)
I've used the "Panel" to scan my pics. Working like a charm.
Anonymous
  • 255 Answers
  • Posted on Jun 22, 2009
SOURCE: Vista OS Driver for Mustek 600 CU Scanner
download from the link
http://www.lostmydrivers.com/
regards
ehsanullah
Anonymous
  • Posted on Feb 07, 2010
SOURCE: Mustek Be@rPaw Scanner 1200CS Drivers for Vista x64 bit
help me download driver on windows vista 64bit.. thanks..
I cant get my new macbook pro to recognize my mustek Scan Express A3 USB 1200 pro, and i haven't been able to find a driver to fix it so far.
Here is the page to download the drivers you need for the Mustek ScanExpress A3 USB 1200 Pro Scanner:
http://www.mustek.com/mustek/supportdrivers.php
Hope this helps!
Remember to give me 4 Thumbs Up
for all the hard work to the Community! :D
~~Dayminner
I have a scanner Bear paw 1200 cu plus, recently a I purchased a laptop but the problem is that whenever I installed a scanner driver a message appears 32 bit driver is not supported to your product you...
on this page:
http://www.mustek.com.tw/Support/
click on support and you are redirect to download page. On this page select your model and you can download driver for Vista 64 bit.
If I could be of further assistance, let me know. If thishelps or solves the issue, please rate it and give a testimonialfor my response.
Computer doesn't see scanner
Google the most current drivers for your hardware.
My screen comes up with the Insfficient memory
it could be ether hardware or software problem. try installing the scanner on a friends computer and see if it does the same thing. if it does then your scanner if faulty, if not then try uninstalling you scanner drivers restart your computer and go to http://www.mustek.com.tw/Download/driv_scanr/europe/b4800tapro.html
to download the new drivers to reinstall.
Can't select OCR language in settings for Mustek 1200 UB Plus usb
the mustek pb1200 ub is the same as the packard bell bear paw 1200 try the software for that
2helpful
2answers
Mustek scanner will not work with vista
can you tell me whyno drivers for vista are available from mustek for my bearpaw 4800 ta pro . Is it possible somehow to get the scanner working ? or is it throw it in the bin time! Thanks Ted
How to instal Mustek cu 600 scanner with win xp
there is not drivers or software made for Windows XP.
however, you can use the win98 or WinME software. as long as the Windows Xp is running at 32 bits. I have done that with HP flat bed scaner.
don't worry about the non-certified software with MS.
1helpful
3answers
Top Mustek Office Equipment & Supplies Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Mustek Office Equipment and Supply Expert? Answer questions, earn points and help others
