Hi
I have a panasonic vcr (PV-V4524S) it was working fine till last week. when we shifted it from one room to another. now when i start power the vcr is okay but when i put a cassettee inside it power is shut. i cannot rewind, play or forward a cassette. in all the cases power is tripped.
The problem is caused by the idler assembly which controls play, record, rewind, and fast forward. If the take up reel stops, the vcr senses a problem and will stop the tape. The only other thing it can be is the drive belt, sometimes it will stretch and fall off or break. I suggest a tv technician or somebody that knows their way around a machine.
There's nothing wrong with your VCR. Your remote probably set to control your TV. To fix that, simply press the VCR button on the remote, and you should be fine. The "T-U" really means "TV," but the designers at Panasonic wanted to use the standard seven-segment display to cut costs, hence "T-U" instead of "TV."
This is indeed a faulty IR sensor. If it's just the sensor, swap with your good one to check. From memory they are plug in - a little device behing d the smoked translucent facia (display panel). I have come across this several times with Panasonic VCRs. Check whether the remote works at night time with all fluorescent lights in the room switched off. If so, the IR filter circuitry is faulty. Same solution - replace IR sensor on VCR.
