If your ear buds have been connected to any device before your TV then it won't work. If you want to connect it to your TV you turn on your headphones, hold the call button for 3 seconds, and you will see ur light flash and connect it to your TV. If this didn't help then go to the manual and check how to connect your headphones to your TV.
Instructions
Set up the transmitter. Wireless headphones rely on a transmitter that sends audio via infrared or radio waves to your headset. Use the digital audio output (coaxial or optical), RCA outputs (red and white) or headphone jack on your TV to connect the transmitter. The connection will depend upon which outputs are available on your TV and/or the transmitter.
Use an RCA-to-headphone adapter. If you don't have a headphone jack on your TV and the transmitter includes only a headphone connection, connect an RCA-to-female headphone connector. This will allow you to plug the wireless transmitter into the female headphone end and then hook the RCA ends into your television's audio outputs. You may also need a 3.5 mm (mini jack)-to-1/4-inch adapter if the headphone plug on the transmitter doesn't match the television jack.
Read more : http://www.ehow.com/how_4883556_use-wireless-headphones-tv.html
Set the transmitter on top of, or next to, the television. For infrared transmitters, you'll need a direct path between the headphones and the transmitter. Placing the transmitter on or near the TV will allow you to take advantage of the clear path you already have.
Plug in the transmitter and turn it on. Charge the headphones if necessary.
5
Turn on the headphones. Adjust the volume and settings and you're ready to watch TV.
Normally the wireless headphones have a transmitter that send audio via wireless to the wireless headphones. The transmitter needs to be plugged into the headphone outlet on the TV. This will switch off the speakers on the TV and sends the audio to the wireless headphones.
Hi, First you need to make a test to adjust your headphones wireless system.. .pls follow the step below:
"Connect the headphone base" TO " headphones
output of TV" with 3.5mm stereo headphone jack cable (than Tv should
mute ) Infra red headphone pilot lamp should flicker in parallel to voice coming from TV
Infra red headphone should have a rotary adjustment on it.. "Volume" adjustment
while TV talking , when you sit in front of the Infra red headphone (it works point-to-point ) you will hear the voice of TV, than adjust volume properly...Thats it..now lets go to second step..
Your headphone's Base should either "3.5mm stereo headphone jack" or "RCA Stereo jacks" or "bot"h..After completion of this test ,I recommend you to
switch / use "RCA Audio output plugs-white/Red cable " on the back of
TV instead of TV's headphone output ,since it mutes the whole sound..RCA
output plugs of TV work independently from the TV's master volume control..of course you need RCA cable to connect this..
Hope this helps!..if more help requires pls let me know. Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to continue for Helping out the Community :)
you need a stand alone tv tuner with audio/video out
how to install:
1. connect tv antenna to tv tuner
2. connect tv tuner video out to tv
3. connect tv tuner audio out to your wireless headphone control tower.
If you have connected your headphones directly to a headphone jack on your TV, it should work - check whether there is a separate headphone volume control.
If you have connected your headphones to the red/white "variable output" or "Line out" jacks on the back of your TV, these do not provide a headphone-level signal.
Please provide more detail on exactly how your headphones are connected to your TV, what make/model TV you have, and the connections between the two.
