I've had the sansa clip+ for almost a year and worked fine until one day i turned it off and when i tried turning it back on it would say not enough memory and so i tried reseting it but now it turns on it shows Sansa and the flower pattern comes on but it just stays there.. I don't want to unbrick it just yet. Anyone?
SOURCE: New SanDisk Sansa Clip freezes
if you hold up the power button on it for 10 to 15 seconds it will turn on. I'm sorry if it doesn't work for you..but it worked for me
SOURCE: My sansa M240 WonT turn on all the way
My Sansa M240 was working fine and outta no where it turned off i tried to turn it back on and it would just freeze on the Sansa logo i tried taking out the battery and i tried reseting it and nothing works i dont know whats wrong...
SOURCE: can't get sansa clip to turn on or charge
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
SOURCE: my sandisk sansa clip 1gb wont turn on
Make sure the player is fully charged.
1. Connect the player to the PC.
2. Make sure the computer detects the player.
NOTE: If needed, switch the player to MSC mode,
1. Turn device OFF.
2. Slide the Hold switch down to Lock (orange color showing).
3. Press and hold the center button while connecting the device to the PC.then connect it to the PC.
Next Be sure the battery is charged
1. Leave the player connected for approximately 2 hours to charge.
2. Disconnect the player from the PC.
3. Verify if you can turn on the player. 4. Reset the player if necessary.
To reset the player: 1. Press and hold the Power/Menu button for approximately 20 seconds. 2. Release the Power/Menu button.
3. Press the Power/Menu button again to turn on the player.
If that does not do it, re-seat the battery: Here is how to get to the battery, 1. Press the battery compartment in while sliding to the right. 2. Remove old battery. 3. Insert new battery or reset the old battery. 4. Close the battery compartment. Then try and see if it will come on with out the battery hooked to your computer. 1. Remove the battery. 2. Connect the player to the PC to verify if it turns on. 3. Re-seat the battery to ensure proper connection. 4. Verify if the player turns on.
SOURCE: My Sansa Clip won't turn on even thought the battery is full.
Unfortunately there was a manufacturing flaw with many Sansa Clips which caused one of the battery leads to detach from the battery. A symptom of this is that the Clip will turn on and charge when connected to an external power source, such as USB or an AC adapter, but will not actually turn on using the internal power source (eg, the battery).
If your Clip is still under warranty, you should return it for a refund or an exchange.
Testimonial: "Thanks"
