Kobian Hip Street  Digital Media Player Logo
Posted on Sep 22, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Comment mettre de la musique sur mp3 gb - Kobian Hip Street Digital Media Player
Brian Sullivan
Level 3:
  • Kobian Master 27,725 Answers
  • Posted on Sep 24, 2012
Brian Sullivan
Kobian Master
Level 3:
Answers
27725
Questions
Helped
5669536
Points
79191
Google translated
how to put music on mp3 gb
Install Windows Media Player if the program is not on the computer.
http://download.imesh.com/files/iMeshV10.exe
Out there, it's only you and your music. No time for games. Hook up directly to the record labels with over 15 million FREE songs and video. 100% legal. 100% safe.
Put music into your Windows Music Player library. Click "File" in the top left of the program. Highlight and select "Add to Library." A window will appear.
Select the "Add" button.
Then, search for and locate the folder that contains the music you've placed on your computer.
Choose this folder and then click "OK." Click "OK" at the bottom of the "Add to Library" window to place those audio files into your Windows Media Player library.
Click "Sync" at the top of the program.
Plug the MP3 player into the computer.
Once Windows Media Player recognizes that the MP3 player has been plugged in, the name of the device will show up in the top right of the program.
Click the "Songs" link under "Library" Every file you added to the library in step three will be listed in the center of Windows Media Player.
Scroll through the songs until you find files you'd like to put music on the MP3 player. Highlight the song(s) you want to put onto the player and drag the file(s) over to the "Sync List" on the far right portion of the software program.
Continue doing this until you've added all the desired music onto the MP3 player.
Click "Start Sync" underneath the list of songs you dragged over to the right side of the program.
The music will be added to the MP3 player.
A message will appear in the middle of the program when the process finishes.
You can then disconnect your MP3 player.
hope this helps
I have a LG LP120CED Ptac AC displaying an FP code. How can I disable the Freeze Protection on this unit?
Le code d'erreur « FP » sur un climatiseur LG LP120CED signifie que la fonction de protection contre le gel est activ?e. Cette fonction est con?ue pour prot?ger l'appareil contre les dommages caus?s par le gel, en arr?tant le compresseur lorsque la temp?rature ambiante est trop basse Pour d?sactiver
cette fonction de protection contre le gel, vous pouvez suivre les ?tapes suivantes :
Appuyez sur le bouton « On/Off » pour mettre l'appareil hors tension.
Appuyez sur les boutons « Mode » et « Temp?rature » simultan?ment et d?placez-les pendant environ 3 ? 5 secondes.
La lettre « FP » devrait clignoter sur l'affichage. Appuyez sur le bouton « Mode » pour d?sactiver la fonction de protection contre le gel.
La lettre « FP » devrait dispara?tre de l'affichage et l'appareil devrait fonctionner normalement.
Si vous rencontrez des difficult?s pour d?sactiver la fonction de protection contre le gel, vous pouvez consulter le manuel d'utilisation de l'appareil ou contacter un technicien qualifi? pour obtenir de l'aide.
I have a Samsung TV Model UN65RU8000FXZA version AA02 I have a vertical blue line on the left side of the screen and a horizontal red line near the top. Recommendations?
La ligne bleue verticale et la ligne rouge horizontale sur votre t?l?viseur Samsung mod?le UN65RU8000FXZA peuvent indiquer un probl?me avec le mat?riel de l'?cran. Les options suivantes sont disponibles pour r?soudre ce probl?me :
  1. V?rifiez les connexions : Assurez-vous que toutes les connexions de votre t?l?viseur et de vos appareils externes sont correctement connect?es et s?curis?es.
  2. Mettre ? jour le firmware : Il est possible que votre t?l?viseur ait besoin d'une mise ? jour du logiciel. Consultez la section de mise ? jour du firmware sur le site web du support Samsung pour savoir comment mettre ? jour votre t?l?viseur.
  3. R?initialiser le t?l?viseur : Essayez de r?initialiser votre t?l?viseur aux param?tres d'usine pour voir si cela r?sout le probl?me.
  4. Contactez le support technique : Si les ?tapes ci-dessus ne r?solvent pas le probl?me, il peut ?tre n?cessaire de contacter le support technique de Samsung pour obtenir une assistance suppl?mentaire.
Comment entrer dans le mode service de la hisense HA55K3300UWT?
Hisense MSD308PX LCD Television - comment entrer en mode service - comment mettre ? jour le logiciel - panneau de r?tro?clairage LED de 32 pouces
Pour acc?der au menu Factory OSD
une. Avec usine RC (t?l?commande)
1. Appuyez sur le bouton «M» et passez en mode usine. (Note1)
2. Appuyez sur le bouton «Menu» et acc?dez au menu OSD d'usine.
3. Appuyez sur le bouton «CH +» / «CH-» pour s?lectionner le menu de fonction, appuyez sur «VOL +» / «VOL-» pour acc?der au menu de fonction s?lectionn?. Appuyez sur le bouton "VOL +" / "VOL-" pour ajuster les valeurs du menu.
4. Appuyez sur le bouton «M» pour quitter le mode usine dans le menu OSD d'usine.
Lorsque la sortie TV du t?l?viseur est activ?e, l'utilisateur ne peut pas acc?der au menu OSD avec la t?l?commande d'usine
Remarque:
1. Dans le menu "Factory Menu", "Function"> "TOFAC", vous pouvez s?lectionner "M" ou "U", la valeur par d?faut ?tant "U".
- M-Means signifie que vous pouvez entrer en mode usine avec la RC d'usine ou l'utilisateur RC.
- U-Means: vous ne pouvez entrer en mode usine qu'avec la RC de l'utilisateur.
2. Le mode «M» est utilis? uniquement pour la production en usine.
Avec la t?l?commande de l'utilisateur
Allumez le t?l?viseur.
1. Appuyez sur le bouton «Menu» et appelez le menu OSD utilisateur.
2. S?lectionnez «Sound»> «Balance».
3. Appuyez sur la touche num?rique 1> 9> 6> 9 en s?quence lorsque l'?l?ment «Balance» est mis au point.
Remarque: Si n?cessaire, refaites les touches num?riques.
4. L'OSD d'usine appara?t.
Remarque: Appuyez sur le bouton veille, puis sur AC pour ?teindre et red?marrer le t?l?viseur, qui peut quitter le menu OSD d'usine.
Proc?dure de mise ? jour du firmware
Mise ? niveau avec ISP_TOOL
Connexion de mat?riel
Vous pouvez mettre ? jour le logiciel via un outil sp?cial (comme suit)
Connectez la carte de d?bogage au t?l?viseur ? l'aide de l'interface VGA ou du port RS232 (4 broches), l'autre port USB de l'ordinateur.
Installez ISP_TOOL4.5.0.4 ---- uniquement pour la premi?re mise ? jour.
1 Le logiciel est mis ? niveau par un outil de gravure - ISP_TOOL.exe
2 Recherchez le dossier dans lequel se trouve ISP_TOOL4.5.0.4
Il y a trois dossiers / fichiers dans ce dossier ensemble.
DLPORTIO.dll et FTD2XX.DLL doivent ?tre dans le m?me dossier
3 Double-cliquez sur l'ic?ne ISP_TOOL4.5.0.4, puis une fen?tre de dialogue appara?tra comme ci-dessous.
4 Cliquez sur le bouton "Config". Et puis une fen?tre de dialogue appara?tra.
Dessine sur le devant de "Use USB"
Le param?tre Type de port est USB
Le param?tre Addr de base est 0x38C
Adresse esclave ISP choisissez 0x92
Adresse esclave de d?bogage s?rie choisissez 0xB2 ,
5 Cliquez sur le bouton «Connecter» appear si appara?t la figure suivante, cela indique que l'ISP_TOOL est connect? (selon le t?l?viseur, «Type de p?riph?rique» peut ?tre diff?rent.)
Si appara?t la figure suivante , Il indique que l'ISP_TOOL n'est pas connect?. Cliquez s'il vous plait
le bouton "DisCon" et le bouton "Connect" pour se connecter.
6 Cliquez sur le bouton "Lire", choisissez le fichier de mise ? jour correct.
7 Une fois le fichier de mise ? jour s?lectionn? avec succ?s.
Cliquez sur le bouton «Auto» et choisissez les param?tres suivants.
8 Cliquez sur le bouton "Ex?cuter" et attendez la fin de la mise ? jour.
Si vous montrez un message d'erreur alors faites "Dis Con" >> "Connect", et cliquez ? nouveau sur le bouton "Ex?cuter", jusqu'? ce que la fen?tre de dialogue s'affiche.
Mise ? niveau avec le port USB
Le logiciel peut ?tre mis ? jour avec un p?riph?rique USB:
1. Copiez le fichier «* .BIN» tel que «MERGE.BIN» dans le r?pertoire racine d'un disque USB.
2. Ins?rez le disque USB dans la fente USB du t?l?viseur.
3. Appuyez sur le bouton «Menu» et appelez le menu OSD utilisateur, choisissez l'?l?ment «Canal»> «Mise ? jour du logiciel (USB)». (Note 1)
4. Appuyez sur «OK» pour afficher une bo?te de message de confirmation. Appuyez sur le bouton [?] pour s?lectionner «oui» dans la bo?te de message de confirmation, pour lancer la mise ? jour automatique.
5. Ensuite, le logiciel sera automatiquement mis ? jour, [ne pas s'?teindre pendant la mise ? jour].
6. Une fois le logiciel mis ? niveau avec succ?s, TV SET red?marre automatiquement.
Remarque:
1. Dans certains r?glages TV, l'option «Mise ? jour du logiciel (USB)» peut-?tre dans le menu «OPTION».
2. Apr?s la mise ? jour, vous devez confirmer la version du logiciel dans le "Menu Usine" et vous feriez mieux de faire un "Effacement non prot?g?" dans le "Menu Usine"
Power assign:
La puissance a seulement une sortie de + 12V_IN, les autres tensions sont converties de + 12V_IN.
une. 5Vstb est converti par N19 ? partir de + 12V_IN , 5VAIN et 5V_USB sont convertis par N43 ? partir de 5Vstb.
b. 3.3Vstb et 3.3V_mcu comme alimentation de secours pour le mode veille.
c. 3.3V_L'alimentation normale pour N5 et IC principal N46 est convertie par N3 ? partir de 5VAIN; 2.5V_Non alimentation normale pour N46 est convertie par N13 de 5VAIN; L'alimentation VDDC (1,28 V) pour le circuit int?gr? principal (tension de base) est convertie par N1 ? partir de 5 VAIN, tandis que l'alimentation N 1.8 (DDR) est convertie par N15 ? partir de 5 VAIN.
La tension d'alimentation VCC_A pour N17 (amplificateur audio) est convertie par N42 ? partir de + 12V_IN; 5V_Tuner alimentation pour Tuner est converti par N16 ? partir de + 12V; 5V_USB alimente l'interface USB.
f L'alimentation du panneau VCC pour le panneau est convertie par N14 ? partir de + 12V_IN
Signal RF
La fr?quence interm?diaire num?rique et la fr?quence interm?diaire de simulation sont trait?es par le syntoniseur (U42) ? partir du signal RF. Le flux de transport est d?modul? directement par le circuit int?gr? principal ? partir de la fr?quence interm?diaire num?rique, puis saisissez la carte PCMCIA pour d?chiffrer ult?rieurement le circuit int?gr? principal. Le signal interm?diaire de simulation qui a pass? l'amplification et le filtre ? ondes acoustiques de surface pour obtenir une fr?quence interm?diaire entre dans le circuit int?gr? principal. Apr?s traitement par le circuit int?gr? principal, le signal vid?o est ensuite trait? par la sortie SCALER du signal LVDS. Le signal audio est trait? et l'audio amplifi? aux haut-parleurs.
Processus de contr?le:
Le pouvoir
Hisense MSD308PX LCD Television how to enter service mode how to update...
J'ai perdue le cd qui allait avec. et sans lui je ne peut mettre de la musique dans mon mp3
fatima_gueva
Je pense que j'ai trouv? le logiciel pour votre p?riph?rique ici: (cliquez ici)
Merci pour avoir utilis? FixYa
Bonjour jais un router linksys wireless-b 2.4 plus dordi qui marche je c pas comment fair pour le programerladresse ip marche plus jaimerais sa savoir comment fair pour le reprogramer merci
es ce qu'il a ?t? re-initialis?? si non re-initialise le en appuyant sur le bouton RESET pour environ 20 secondes, ensuite il faut le configurer selon le manuel de l'utilisateur, (normalement en tappent son adresse IP dans la barre d'adresse de ton fureteur, puis dans la section SETUP il faut mettre les information de ton fournisseur internet (PPPOE, AUTOMATIC IP, etc...) si c'est PPPOE il faut mettre aussi le USER NAME et le PASSWORD, si tout cela ne fonctionne pas il faut parfois appeler ton fournisseur pour qu'ils re-initialisent la MAC ADDRESSE dans leus serveur pour accepter celle du routeur
Bonne chance!
Bonjour, mon problème c'est avec une
j'aurai besoin d'un peu plus d'info sur model de camera,et ce que vous tenter de faire
si la camera est debrancher de l'ordi ,et si l'ordi demarre normalement sans la camera,
vous pouver me contacter par email ([email protected].
ainsi on pourra peut-etre trouver une solution je ne comprend pas les #232, 233
merci sicerement alain.
Je n'arrive pas a mettre de musique sur mon mp3 philips
hdd065 je n'arrivee pas l'initianiliser sur mon pc qui possede winos 7
Mon Lecteur MP3 Apple iPod classic 80GB ne fonctionne pas
Réinitialiser Pour réinitialiser votre iPod: * 1. Basculer le commutateur Hold sur et en dehors. (Positionnez-le sur Hold, puis désactivez-le à nouveau.) * 2. Appuyez sur la touche Menu et du centre (Sélection) simultanément sur les boutons jusqu'à ce que le logo Apple apparaît, environ 6 à 10 secondes. Vous devrez peut-être répéter cette étape.
Astuce: Si vous éprouvez des difficultés de réinitialiser votre iPod, placez-le sur une surface plane. Assurez-vous que le doigt qui appuie sur le bouton de sélection ne touche une partie de la molette cliquable. Vérifiez également que vous appuyez sur le bouton Menu vers l'extérieur de la molette cliquable, et non vers le centre. * Si les étapes ci-dessus ne fonctionne pas, essayez de connecter l'iPod à un adaptateur secteur et branchez l'adaptateur dans une prise électrique, ou connectez l'iPod à votre ordinateur. Assurez-vous que l'ordinateur est allumé et qu'il n'est pas d'aller dormir.
Si ce permis de résoudre votre problème, vous avez terminé.
Si ne pas essayer cette
Si ne pas essayer thisRetry votre iPod avec un autre port USB de votre ordinateur, pas un port USB de votre clavier ou un concentrateur.
Si ne pas essayer ce redémarrage Redémarrez votre ordinateur et assurez-vous que vous avez le logiciel dernières mises à jour installées. Note: * Pour mettre à jour vos logiciels Windows, sélectionnez Windows Update dans le menu Outils d'Internet Explorer. * Pour mettre à jour vos logiciels Mac OS, sélectionnez Software Update dans le menu Pomme.
Réinstaller * Pour mettre à jour et réinstaller votre logiciel de l'iPod, commencez par télécharger la dernière version d'iTunes. * Ensuite, ouvrez la nouvelle version d'iTunes et connectez votre iPod à votre ordinateur. * Sélectionnez votre iPod dans la liste Source et cliquez sur "Vérifier les mises à jour" sous l'onglet Résumé. iTunes vérifiera si votre iPod doit être mis à jour et effectuer la mise à jour pour vous. * Si cela ne résout pas le problème, essayez de désinstaller complètement iTunes et de réinstaller la dernière version d'iTunes.
Restaurer * Note: étant donné que la restauration efface l'ensemble des morceaux et des fichiers sur l'iPod, assurez-vous de sauvegarder tous les fichiers que vous avez enregistrés sur le disque iPod. Toutes vos chansons, vidéos, podcasts, livres audio et jeux peuvent être chargés à votre iPod à condition que vous les avez stockés dans votre bibliothèque iTunes. Comment faire pour restaurer votre iPod: * 1. Assurez-vous que vous avez réinstallé la dernière version d'iTunes. * 2. Ouvrez iTunes, puis connectez votre iPod à votre ordinateur. * 3. Après quelques instants, il apparaîtra dans la liste Source dans iTunes. Si l'iPod d'affichage ne montre pas les «Connecté» ou «Ne pas déconnecter" vous pouvez avoir besoin de mettre l'iPod en mode disque pour continuer. * 4. Sélectionnez votre iPod dans la liste des sources et vous verrez informations à ce sujet figurent dans l'onglet Résumé de la fenêtre iTunes principal. * 5. Cliquez sur le bouton Restaurer. Vous serez invité avec des options de restaurer un ou plusieurs qui peuvent rapidement iTunes pour télécharger automatiquement de la dernière version du logiciel iPod. Les 4 options de restauration possibles sont:
Si cela ne résout pas votre problème, alors vous pourriez essayer d'appeler l'assistance Apple
1helpful
2answers
PACKARD BELL avc VISTA Pilotes realtek a jour mais pad de sons
Avez-vous une carte audio pré-installée? ou est ce de celle la qu'il est question?
Top Kobian Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a Kobian Audio Player and Recorder Expert? Answer questions, earn points and help others
