How to i open unlock mouse pad option
Click the Windows "Start" button in the bottom-left corner of your desktop. Scroll up and click "Control Panel." Choose the "Mouse" icon or type "Mouse" in the field in the upper-right corner. Click the "Enter" button and then click the "Mouse" link. Press the "Hardware" tab or the tab to the right of it that specifies the type of touch pad you have. If you are under the "Hardware" tab, highlight the touch pad in the list of devices and click the "Enable" button. If you are under the touch pad tab, click the enable button.
Click the "Apply" button and then click the "OK" button
or Locate the function key on your keyboard (F1 through F12) that has an icon of a touchpad. This is often a rectangle with two smaller rectangles below it, representing the touchpad and its two buttons. Press and hold the "Fn" key, usually found in the lower left area of your keyboard. Press the touchpad function key and then release both keys. If this does not enable your touchpad, try holding the "Fn" key down and pressing the touchpad function key twice in a row.
Shortcut Key Method
Press the Windows icon key on your keyboard and hold it down until the Start menu pops up. If your keyboard doesn't have a Windows icon, press "Ctrl-Esc" at the same time. Use your arrow keys to locate the Control Panel and press "Enter." Navigate to "Mouse" with your arrow keys and press "Enter" to open the mouse control dialog box. Then, press "Alt-F" together to access the tabs at the top of this box. Navigate using the arrow keys to "Device Settings" or "Touchpad" or the similar option on your system and press "Enter." Press the "Tab" key until the "Enable" option or a check box next to it highlights and then press "Enter." Press "Tab" again until you are highlighting "OK," and press "Enter." Your touchpad will be re-enabled.
hope this helps
depending on your laptop this will vary
If the Fn (Function) button at the bottom left of the keyboard is pressed in conjunction with some other key on the keyboard it can result in the disabling of the mouse pad.
To enable your mouse pad on a Windows PC go to the Control Menu.
Under the Printers and Other Hardware option, click on Mouse.
Then, click on the tab on the top of the pop-up menu that says Device Settings.
The touch pad for your computer should come up as a selectable option.
Click on it and you will see the option to enable your device, then click OK
or
Right-click on a blank spot on your desktop. Scroll down, select "Personalize" and then choose "Mouse Pointer."
Click the "Device Settings" tab. Highlight your TouchPad in the "Devices" section. Hit the "Enable" button.
Click the "Apply" button and then click the "OK" button.
or
Click the "Start" button in the lower-left corner of your computer.
Type "mouse" in the field above the button. Click "Mouse" in the list of items that appear.
Click the "Device Settings" tab. Highlight the touchpad item in the "Devices" list.
Click the "Enable" button. Click the "Apply" button and then the "OK" button.
hope this helps
