Hi, I have a Porcher P2749 toilet that is leaking via the overflow pipe. The overflow mechanism seems to "stick" after a flush, meaning it cannot then cut off inflow on the next fill. Is this a common problem? And any suggestions for a simple fix would be appreciated. Thanks
SOURCE: american standard cadet 3 leaking around seal
get a new filler assembly. the water in the tank is heavy enough to close the seal completely. or the rubber seal is not making contact. thats' why the leak.
change the whole assemble ususally correct the problem.
adjuste the flow to about 1/4 to 1/3 under the over flow. if that still don't give you the pressure. you ca adjust the flow tube to 1/5 under the cover. that is the max.
SOURCE: Possible toilet leak or doesn't stop running...
this sounds like the ballvalve needs replacing & the hissing is the sound of water as the valve is not shutting off properly.
The valve at the bottom of the tank is possibly just a half turn valve so try that & see if it stops the water.
The water leaking could be thatthe water level is too high & leaking around the handle assembly & running down, so it kinda looks as though its leaking below?
The handle assembly may of come adrift so thats whay the handle may look loose ?
Solution sounds quite straight forward, a new ballvalve assembly needs to be fitted & the handle assembly sorting.
The leak will be rectified when you replace the old ballvalve, as you will need to turn off the water to the unit to remove the ballvalve, whilst the water is off a service valve should be fitted so as any future probs or servicing needs doing then it can be isolated without the need for turning the whole house off?
This work should be carried out by a registered plumber & is as i said a straight forward job.Price approx £65.00 subject to a survey by the plumber.
I hope this has helped
kindly
Richie
SOURCE: American Standard Elongated toilet bowl water level slowly drops
The tank holding the proper amount of water is a good sign. The inside of the stool is like the GOOSE NECK under you sink. It always holds water. This may sound like a bit of a hassle to do but if all 3 toilets are identical, here is what you can try if you are a bit handy. Go to the hardware store and purchase 4 toilet wax rings with a plastic flange and a few sets of toilet floor flange bolts(they are cheap and you can always return if not used, as It is better to have xtra parts on hand). Turn off the water supply to the "Mystery Toilet". Leave the tank and everything connected to the stool. Flush the toilet and remove all excess water from the tank and bowl. This can be done with a shop vac, sponge or towel. Disconnect the water supply to the tank. Remove the bolts holding the stool to the floor and carefully remove toilet. Scrap off all the old wax from the floor flange and bottom of stool. Now go and repeat this proceedure to one of the toilets that is working properly. In other words Switch the "Mystery Toilet" with a "Working Toilet" and see how they react. If the working toilet does it in the same bathroom and the "Mystery Toilet" does not do it in the other bathroom then you probably have a VENTING PROBLEM. If the "Mysery Toilet" Does it in the other bathroom then you most likely have a Defective Toilet. This Job is best done by 2 people, as it can sometimes be challenging to center the new wax ring on the toilet flange. Reconnect to the floor and reconnect water supply to the tanks. DO NOT OVERTIGHTEN BOLTS to the floor flange as you may crack the toilet. All drain lines must be vented properly for water to flow. If you are curious check out drain venting on the internet. Also, sometimes a vent can become obstructed with debris, ice, bird nest, etc.. I would 1st check the vent on the roof visually and then have someone flush and listen. If you believe the vent is clear....Then do the toilet switch and go from there.....Hope this helps and Happy Holidays....Joe
SOURCE: My toilet is leaking around the flapper. It does
remove old flapper, go to local hardware store and get a replacement for about $4.
do not forget to turn water off and flush it to clear the tank first. clean the fapper seat too.
SOURCE: toilet keeps filling tank every 10 minutes
If there is no water on the floor then the water is leaking down the main tank drain. Take off the tank lid, turn off the water supply to the toilet. Fllush as much water out as you can. Look at the main drain, sometimes if the flapper valve is connected with a chain, the chain can get caught between the flapper valve and the drain hole, the flapper valve is pliable so it tries to seal around the obstruction but can't always do it. Make sure there is obstruction, that the flapper valve is not out of shape or old and non-pliable and that it lines up with the drain hole and doesn't get "hung up" on anything.
