Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
Karen Skoda Posted on Apr 22, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Whirlpool washingmachine During the filling cycle, the oold water trickles in. The hot is fine.
  • Anonymous Apr 07, 2009
    I have cleared the screen, but still water trickles in. Is there a filter inside the unit, if so, how do I get to it.
Anonymous
Level 3:
President:
  • Master 878 Answers
  • Posted on Apr 22, 2007
Anonymous
Master
Level 3:
President:
Answers
878
Questions
Helped
1201914
Points
3312
Karen, start by removing the cold water hose to the inlet valve in back. It will have a screen in the inlet valve. Make sure the screen is clear of sand and debris. Start there and post back. Catriver.
Water fills at a trickle during rinse cycle and NEVER fills up.
check urt water inlet valve and urt water pressure swttich
My washer will fill with water during the wash cycle just fine, but during the rinse cycle the water just trickles in. The water lines seem to be fine. What else could be causing my problem?
usually the wash is a mix of hot and cold and the rinse is just cold, that said, it is most likely a problem with the cold water supply. check to make sure the cold water valve is all the way open and the hose isn't kinked. If those are ok turn the water supply off and remove the supply lines on the machine side, you will see a screen inside the washer that may be clogged with sediment. If so, just clean it out and put it back together. You may also want to run a wash cycle on cold only to see if it fills slowly for the wash cycle. If it does fill slowly on cold you have low pressure on the cold side.
The water fills very slowly on rinse
You probably have a cold inlet valve with restricted flow, either because the filter on the inlet valve is clogged or because the cold valve is failing......If you wash on "warm" you have both hot and cold water mixed. On rinse there is probably only cold water used....Check water flow for HOT and COLD settings and you'll probably see the difference...Good luck...Nomess
Water pressure for Washer (rinse only)
you nead to turn off both cold and hot water.next you nead to remove cold water hose from washer.remove screen and clean it and replace it.hookup cold water hose to washer and turn water back on.you should have better pressure.your rince cycle is cold water.
Cold water in the rinse cycle of the washer just trickles
Sounds like cold water solenoid is not opening all the way, its easy to replace, and is found inside the wash machine where the hose connects
4helpful
2answers
I have the washer on cold water, but it runs warm, stops, trickles, then comes out warm again, stops, trickles, then warm again ect.On the rinse cycle it will only trickle out.
The water fill valve - The water fill valve is a mechanical and electrical part, the coils on the valve need electricity to mechanically open the valve to allow the water to flow into the washer....myth....the washer pumps water into itself...no, it does not. The fill valve opens and the house water pressure pushes the water into the washing machine.
No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can test a fill valve live for 120 volts, power to a fill valve coil and no fill = a bad fill valve. You can also test the coils for continuity, no continuity = a bad fill valve. Some Maytag washers have a fuse in the fill valve circuit, if this fuse let go the washer will not fill. Fill valves can also from time to time stick open and not stop filling. If you have to shut off the fill valves to stop the water from filling in the washer, you have a bad fill valve and you will have to replace it.
2helpful
2answers
Just a trickle of water during rinse cycle
HI thanks for your question. the cold water valve either has a clogged screen or a faulty water valve. remove the cold water hose and clean out the screen, try again. could be all you have to do. if its acting the same. replace the water valve. thanks the appliance doc. please rate my answer. thanks.
2answers
Washer fills slow only in the rinse cycle
I had the same problem with my Kenmore Model 11022956102 washer and first thought that it was the water inlet valves. So I replaced them, but found the problem continued. After about 25 seconds into the rinse cycle the water only trickled in. Checking with a voltage meter I found that I lost 120V at terminals 3 & 5 on the washer temperature controller after 25 seconds. Even though the wiring diagram doesn't show the water temperature control board, since it's full of resisters and capacitors, I figured it was the most likely problem. So I ordered a remanufactured board from Parts Simple (#3407125), received and installed it. The 17 year old washer is now working fine once again. I hope this helps someone with the same problem. /s/ Paul
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
