My laptop will not boot up. The lights blink momentarily. Then shut off
Did it blue screen of death ?
If you want to keep your important data, use some softwares can solve thewindows won't startproblem most quickly, and no data will lose. Besides, it is very easy, even the people who lack of computer knowledge can deal with windows won't boot issue.
Perform the following steps:
-Remove the battery and Power adapter
-Press and hold the power button for 30-45 seconds (with battery and power still removed)
-Insert just the battery and attempt to boot the laptop.
-Insert just the power adapter and attempt to boot the laptop.
Technical Support ' Hotmail Support
SOURCE: Dell inspiron 1300 Video card upgrade
Sorry you cannot upgrade the graphics on your laptop according to the articles i looked up.
You should call DELL. I think the display card is part of the mother board on your computer. In this case, you cannot change it. In some models you can add some memory to the display card, but this may not make the card faster. Higher amounts of memory allows for more resolution and colours.
SOURCE: Dell inspiron 1300 back light problem
All laptops have a backlight and an inverter to power it, and the problem you have is very common. Usually replacing the inverter board in the display fixes the trouble. There are a number of vendors online offering replacement parts. Here is one that just popped up after a Google search. You can also find videos on youtube showing the procedure for opening up the display to install the new part. It's a simple process that most people can handle with a little patience and some small tools.
It's also possible the light itself has gone bad, but the inverter failure is more common. The backlight on some displays is not replaceable separately. So try the less expensive inverter replacement first.
SOURCE: dell inspiron 1300 does not switch on
try unseating and reseating the memory one stick at a time in each slot one at a time and try turning on the laptop after each stick reinsertion.
If this doesn't do it then take out the hard drive and dvd drive then turn on ht laptop.
If after all of these steps you still don't get video then the motherboard is bad.
SOURCE: Dell Inspiron 1300, no sound.
I updated the BIOS to v A10 (available on Dell site) and the sound came back. Not sure why, but it worked :-)
SOURCE: My Dell Inspiron m5030 won't turn on. It was
Switch ON the PC, boot the PC in
'Safe Mode' by continuously tapping F8 button after you switch On. The
detail of that particular date should show "System Checkpoint" and
time on the right hand side box. Select that date.
Let windows boot in Safe Mode and log in to windows.
Go to 'Start'--->Programs--->Accessories--->System Tools--->System
Restore
Here you will have to check "Restore computer to an earlier time' and
click Next
Now you will find one Month Calendar window with Dates below, go to
the previous month by clicking the '<' sign in the upper left hand
corner of the Month Calendar and select any date that you see in Bold.
Now, Click on Next and System Restore will start and windows will take a
reboot.
Just try this and leave a feedback for next steps.
