Here is also a comprehensive guide on what to do when this happens again in the future:
http://gdgtpreview.com/2018/03/your-epson-printer-doesnt-recognize-the-ink-cartridge-heres-what-to-do
This might ba an issue with the cartridge holder in which its not recognizing inks or inks are defective. Call Epson for cartridge replacement is reinstalling of inks doesn't work.
SOURCE: The printer tells me all the ink cartridges are empty and refuses to print
Hi Blackburn,
Get you some rubbing alcohol and Q-tips. Disconnect the power from the printer and remove the Ink Cartridges. Using the q-tips and soak them with the alcohol. Clean the electrical connections in each of the cartridge ports. You might go through several Q-tips before geting them cleaned up good. If necessary use Finger nail polish remover instead of Alcohol to get any contaminants off of the connections. Test a site with the fingernail polish remover first before dabbing it all over. I am afraid that it may eat up the electrical connections.
SOURCE: Epsom R200 COPY INK DOESNT WORK
There is no solution, I have tried this myself, there are compatible inks for this product, you just got the wrong ones, However it may only be down to one of the inks, check the ink levels before removing, if all empty, then they are not compatible.
swampduck
SOURCE: Epson RX420 new black ink cartridges displaying empty
Normal
0
Could have a corrupt driver.
Disconnect
the printer or at least be sure it is turned off. I'd do
both and when the CD software program asks you to connect the printer
to the USB port, do so and it should again work properly.
Hope this helps. Bud
SOURCE: new ink caretridges not getting accepted by epson stylus cx4400
Try removing the cartridges and cleaning the metal contacts with alcohol where the carts sit
SOURCE: epson rx595, installed compatible ink
Swith machine off
clean pins in cartridge holder with (lightly) damped lint free cloth
Now try with compatibles
By the way, never mix originals with compatibles.
Good luck and don't forget to vote for more sharing.. thank you
