Question about Frigidaire 24 in. PLD3465REC Stainless Steel Built-in Dishwasher
Error code ER then UO any ideas?
It's 30 days old and just started giving me this error code. It fills with water then pops the error code and progress past that part. Error code ER then UO.
  • 8 more comments
  • howeihe Feb 25, 2008
    same problem, help
  • Anonymous May 17, 2008
    I had this problem when I tried running the dishwasher while I was washing dishes in the sink.
    I tried calling the toll-free number, but it's a dead-end. They give you another number to call, but that number answers only during business hours M-F, and my problem occurred on a Saturday. The Frigidaire web site doesn't have information on error messages. The appliance store where I bought the machine was also useless--the guy at the other end only had the same owner's manual that I do.
    Here's what I figured out: It seems that since the sink and dishwasher drain out through the same
    pipe, the dishwasher sensed something wrong with the drain, and after
    filling with water for a few seconds, it put out the "Er -uo" error
    message. So I drained the sink, opened and closed the dishwasher, and lo and behold, it automatically drained itself. After that, I re-set the program, and it ran normally.
    Mike
  • MikeDur Dec 13, 2008
    This is true the vent on the top right rear does use a small spring assisted sensor (really bad design) over time the tension decreases in the spring therefore the cheesy little peice of plastic which goes into the little cheesy guide gives a false location indication which does try 5 times on fill but fails thus giving you the error. Of course no serviceable parts inside the vent assy. And no mention of the design flaw on the unit itself on Frigidaire.com. (There is NO way they do not know about this design flaw due to today technology) If you goe to their web site there is nothing about error codes and any assistance is out of our pocket. Really - I would love to come back and read a post by the guy - girl that designed this great dishwasher vent assy. But doubt it. Merry Xmas everyone I feal better venting, hoping someone else takes the time.
  • Anonymous Feb 08, 2009
    same problem with getting the Er uo code. I JUST had mine installed, it's never actually even ran!! Not pleased. Any suggestions would be greatly appreciated
  • Anonymous May 05, 2009
    Same problem here; same ER uo code. Discouraging.
  • ontik May 06, 2009
    i have a frigidaire dishwasher when i tried to start it ,all of a sudden the CL, started to flash and sensing & washing small green lights start to blink all together. what can this be
  • Wesley Jan 05, 2013
    Same here. Drain dishwasher and restart cycle. Problem solved.
  • Anonymous Mar 25, 2017
    Our Frigidaire dishwasher had the same issue. When turning it on, it would make a clunking sound 4 or 5 times and then display the UO error code. We saw advice that connecting the brown and yellow wires inside the vent would be a temporary fix and that worked as long as you don't use heat-dry but is not safe to do.
    However, as it worked, we knew this meant the optical switch was not closing the circuit and had gone bad. The optical sensor is the tiny component labeled U1 on the small circuit board inside the vent under the fan.
    We ignored the "no serviceable parts inside" warning and replaced it with a nearly identical part from an online electronic components store that cost just 81 cents excluding shipping. We desoldered the old sensor, threaded the leads of the new part into the board and soldered the new part in. We had to clip the wires to the PCB when we removed it and simply resoldered them back. Be sure to label them before you cut them.
    The part was described as an Optical Switch, Transmissive, Phototransistor Output 2mm SLOT TYPE 30V. Specifically, it was made by Omron, model # EE-SX1105. Special tools required were a desoldering iron to remove the old component and a soldering iron and solder to install the new one. if you have soldering skills this is easy - my 15 year old had fun applying his skills. If you don't have soldering skills or equipment you won't want to attempt this unless you can find someone to help. My son only charged me $10 for his labor - it took him about 20 minutes. :-)
  • Alberto Delosrios
    Alberto Delosrios Nov 10, 2017
    You are spot on with connecting the brown and yellow cables to bypass the faulty sensor! As a short term solution this is the way to fix the nagging Uo error. As a mid term solution I went to amazon and bought the vent assembly for $75. And for a long term solution I will never buy Frigidaire again. Thank you!
  • Jenn hernandez May 10, 2019
    Can anyone tell me if the individual small parts inside can be replaced? Somehow the long white arm with the pin in it broke at the piece where the pin is inserted. Any help is greatly appreciated
    New Friend:
So far so good. I fixed mine by removing the vent and even though it says no repairable parts I disassembled it then removed the rubber gasket and cleaned it with a brush under hot water. I then cleaned the plastic ring it seals against. Next I removed the spring and stretched it to make it about a quarter inch longer and then reinstalled the spring then the rubber gasket and then closed up the unit. So far it is working fine. I suspect the real problem is that there is a tiny sensor that needs to be covered when the vent is closed. If this is not covered the uo error code is generated.
Posted on Aug 22, 2009
  • WuhBuh Nov 03, 2010
    Three cheers for Chance_020!!! We pulled out washer out, disassembled the fan box and found our spring loose and partially corroded. I stretched the good piece of spring and reassembled everything. The error is gone!!!
I had the same Er uo problem. I work at LOWES and asked my Appliance manager for help. He said that it was the control Panel, wich is the same thing the 1-800-944 number said. THIS IS NOT THE CASE. He did give me a hint by suggesting I open the door and take the panel off. I did and low and behold there is a paper with scematic and code definitions cliped inside. After reading that the Er uo code means vent open (and comfirming that from a tip i found on this site. I also read that the vent is located in the upper right hand corner of the top of the unit inside. I twisted the GRAY CAP off and saw the black rubber vent i pulled down and noticed it was glogged with soap. I pulled the dishwasher out and took the vent out and cleaned it and then put everything back together. then ran the dishwasher. it ran with no problems for 30 min. then flashed the same Eruo problem. my thought is that the Vent unit has to be replaced i will post more as i find out.
Posted on Sep 10, 2008
  • Jennifer Nesvig
    Jennifer Nesvig Aug 04, 2016
    After reading everything on this thread, I started investigating. The little black piece that goes up into the sensor that tells the computer if the vent is open or closed is a bit short. We put a piece of black tape on the end to make it longer. Running a test run right now to see if it will finish the cycle. I'm expecting an error when it's time to dry. I'm not too worried if it's drys, just washes!
  • Dawn Merrill
    Dawn Merrill Feb 06, 2018
    What amazes me is this specific fault remains in this specific appliance over TEN YEARS after the first post in this thread. I will be using your suggestions tomorrow.
    New Friend:
Error code "ER" then "uo". Top right of washer is a vent. reached in and ran finger around gasket, removed a small amount of gunk. Pulled down on the plate that holds the gasket a few times which reseated it. Closed washer and now works fine.thanks Chance_ 020! Good advice!
Posted on Nov 08, 2009
    New Friend:
UO error code. Cleaning the rubber seal worked for a week. Then the dishwasher would no longer run. 6 years old this dishwasher has been fixed 3 times. I took the vent apart cleaned it. Still getting the error UO. Even holding the vent open or closed no change. the replacement part is 100.00 to much. I can not recommend any one attempt this but I was able to bypass this vent by connecting the orange and yellow wires. The dishwasher now runs again with out error. I would not use the high heat or sanitize functions anymore. But for a basic wash this will work until I can purchase a new non frigidaire dishwasher.
Posted on Aug 15, 2013
  • 2 more comments
  • Simon Beaulieu
    Simon Beaulieu Nov 26, 2013
    I tried all the tips in this page and the only one that fix the UO problem is bypass the vent by connecting the yellow and brown wires (picture). I also isolate the wires after with electrical tape.
  • Frank
    Frank Jun 24, 2015
    This worked great. Thank you very much for the information. My wife and I never use the dry heat option anyway. Our dishwasher is 4 years old + so it did not make sense buying a new valve and taking the chance that it might not be the problem. Frank
  • John Balance
    John Balance Oct 28, 2015
    I left them connected and just jumped them. It worked! Know that this will tell the machine that the vent is closed and it's ok to run. If your vent gets stuck open, you are going to get water up there!
  • Colette Burney Aug 22, 2017
    Thank you, the picture was the most helpful thing I found. I am handy, but my terminology gets a big thumb down. The picture made it easy.
The vent fan on the top right hand side at the back of the dishwasher, has wires coming down the side. The wires were not conected they had to be plugged in. The Er uo code stopped flashing and the dishwasher started working.
Posted on Oct 11, 2008
    New Friend:
I have the er code but not the vo code tryed replacing the control board and messing with the vent but no luck. I turn the power off and then turn it back on it runs for about min. and then goes to the er mode and flashes. there is a s flashing with the er code. what else should i check for?
Posted on Mar 03, 2010
  • 3 Answers
We had the same problem with our Frigidaire dishwasher. We called them and they said the UO stands for Vent Open (the display can't make a V so it makes a U). The active vent was not closing when it should be closed (the repairman said the gasket was stuck up in the assembly so sometimes it would seal and sometimes it wouldn't) and thus the error. Since our machine was still under warranty, we had the vent replaced at no cost and haven't had the problem since.
Posted on Oct 30, 2007
    New Friend:
To let you know with this error "UO" the heat element stays on. it melted the lower spray arm of my dishwasher while we were out
Chance_20 is right about how to fix it.
Needless to say were going to buy a new one and it wont be Frigidaire.
Posted on Nov 15, 2009
    New Friend:
Trent Williams is right about checking and cleaning the optical sensor. I have gotten the vent open error several times in the past and just opened it and removed the built up soap clogs and everything was fine. This time it wasn't enough. I cleaned around the gasket (what I could reach) and still had the error. Decided to remove the screws and disassemble the valve and clean everything properly. Re-assembled and still have the error. Information said it uses an optical position sensor. It is a small sensor on the very small plain circuit board on the back of the valve where the thin stem from the valve slides through when it is in the up position (mine was black). I removed the valve again and using a small stiff nylon brush and lens cleaner I scrubbed that black sensor piece very hard and thoroughly. Re-assembled the unit again and it is working perfectly now. How long it will last I don't know (only has 3 cycles on it so far), but it may be worth not buying a $100+ part for a while longer.
Posted on Jun 23, 2014
I had the same issues. I took my dishwasher out, took off the vent and cleaned the gasket. That did not work. I eneded up opening the unit and cleaning the sensor where the vent arm registers its position on the circuit board with a small wire brush, this seemed to do the trick. I am 10 minutes into a cycle so we will see. I found the replacement part online for $60 and I called a repair person and he quoted me $230 to fix it.
Thank you Internet.
Posted on Mar 26, 2013
  • Lauren Bell
    Lauren Bell Feb 23, 2017
    Where did you find the part for $60?
  • Lauren Bell
    And where is the sensor located? I took it apart last night and cleaned the gunk from the rubber part but did not clean the sensor. Thx
    New Friend:
I had the same issue... cleaned the vent as described in earlier post and everything seems to be working fine now... there was alot of dried soad which obviously was causing the vent to stick. Thanks for the help...
Posted on Mar 17, 2013
    New Friend:
Remove the plastic turn ring on the vent at right rear corner and "slightly' pull down on the rubber part and with a wet hand run your fingers around that part a few times and repeat with a "clean" wet hand...do this a couple times then reinstall the twist lock ring....that fixed mine right up.....it had a lot of white chunks that were easy to clean off with wet fingers....no mour ER UO and away it goes....the "clunk-clunk-clunk" was the tip off that it was stuck.....hobbiehubbcapp
Posted on Mar 03, 2013
  • charles_forg
    charles_forg Mar 03, 2013
    it is working!!!
  • Anonymous Feb 06, 2018
    Ah ha! the clunk, clunk, clunk is explained!
    New Friend:
  1. I have done all that you have suggested. Thank You by the way....
  2. Dishwasher full of dishes with an error code uo still.
  3. chance 20 has it figured out for washers older than 2 days.
  4. I took the vent appart as suggested.
  5. Prox switch is bad within the vent itself. Even holding the vent in the open possition with the vent assembly closed, produced the error message.
  6. I would suggest that if you have a washer never used with this fault, replace the vent assembly. You will hear a ticking sound in the rear right side. When the unit is in installed possition, it will sound as though it is coming from the main door pannel. The ticking sound is the unit calling for the proximity switch to "make" and the prox not sending the signal that it has "made" thus it retries about 5 times before you get the error message.
  7. I hope this helps someone else, but if you are reading this, you have already made the investment of time....Sorry.
Jamie
Posted on Feb 07, 2010
The problem is the quick connect that goes to the vent is loose, make sure its nice and tight
Posted on Feb 27, 2008
    New Friend:
I cleaned the vent on the Upper Right top of the inside and it ran. With hard water running through the machine it gets pretty gunked up. The lesson I learned is to clean it more often. I agree though with previous posters that the design is a little chincy for such a machine. Luckily there are sites like these to help, otherwise I would've paid a tech a hundred bucks to come clean some calcium from the little vent.
Posted on Nov 06, 2010
    New Friend:
I cleaned the sensor by rubbing thin cardboard between the arms. So far so good.
This dishwasher has been a lot of trouble.
Posted on Aug 25, 2018
    New Friend:
Tried cleaning the vent, checked the wires,took apart the vent assembly and cleaned the optical sensor with a toothbrush, stretched the spring....Still not working.
Tried Antone's fix.....(jumping the yellow and brown wires from the close sensor)....YES!!! (thx Antone!)
Keep in mind that this "fix" will only trick the machine into thinking that the vent is closed. If the vent ACTUALLY IS OPEN, the dishwasher WILL CONTINUE TO RUN!!!! Water will then be forced up in there, doing all kinds of water damage! This is for diagnostic purposes....or those who like to gamble ;) I wanted to make sure it was the vent and not the control panel as some have said.
My dishwasher ran like a charm! No clicking or stopping. During the dry cycle, the fan runs but the vent stays closed. I DID stretch my spring to make it stiffer tho, so I'm not sure if I had left that alone, the fan may have pushed open the vent?
HTH!!!
Posted on Oct 28, 2015
    New Friend:
Thanks everybody for your help you saved me a service call. Your suggested fixes worked well. ...just had do clean it up and reassemble & Reinstall.
Posted on Apr 06, 2014
    New Friend:
I opened the vent out unit to clean it and noticed a small spring that fell out of the unit. Where does it go back? Anyone knows? thanks.
Posted on Aug 13, 2011
  • Jesse Tribbey
    Jesse Tribbey Oct 18, 2015
    It goes under the arm closest to the solenoid. There is a little plastic plus sign...it sits on that and under the rocker arm.
    New Friend:
  • 33 Answers
I got the same error code, U0. My problem turned out to be the electrical connector where the vent fan assembly plugs into the dishwasher wiring harness. It had gotten wet, and there was green corrosion on the connector pins. The vent was closing, but the corrosion prevented the signal from getting through. Cleaning the corrosion off the pins, and sealing the connector with some dielectric grease (used on auto spark plug boots - available at any auto parts store) solved my problem.
Posted on Dec 13, 2009
  • TwoHandsDown
    TwoHandsDown Apr 06, 2014
    Thanks everybody for your helpfull comments and the pics. You saved me a service call. Your suggested fixes worked well. ...just had do clean it up, reassemble & reinstall.
    New Friend:
Had this "UO" or rather "VO" error code. Found the vent in the inside, upper right. It had some junk on it and in the inside. Scraped it off set the wash program and it took a minute for it to figure things out, then it started. Thanx forum!!!
Posted on Apr 13, 2010
Anonymous
SOURCE:
LG lfx31945 REFIGERATOR...FREEZER NOT COOLING. ER FF CODE
LG Help Library: Error Codes - Refrigerator ' LG U.S.A
www.lg.com > Home > Support > Product Help > Help Library
  1. Cached
  2. Similar
Feb 26, 2018 - FF Error Code. A FF error code indicates that the unit has detected an issue with the freezer fan. This can sometimes be caused by frost buildup. ... If you notice frost buildup along the walls of the freezer compartment, the leveling and door alignment of the refrigerator will need to be checked.
SOLVED: Error Code ER FF - Fixya
www.fixya.com/support/t121701-error_code_er_ff
  1. Cached
  2. Similar
Oct 18, 2006 - Error Code ER FF Our refrigerator is 1 year & 1 week old. A few days ago it started making a noise that sounded - LG LRBC22544 Bottom Freezer question. SOLVED: Error codes Er rF 10 posts 14 Nov 2013 Lg lfx31925st 00 code er ff 10 posts 21 Sep 2013 SOLVED: How Do You Repair An lg lfx31925st error ... 11 posts 16 Nov 2012 SOLVED: LG refrigerator lrsc26944tt error code ER FF 11 posts 25 Jan 2009 More results from www.fixya.com
FIXED LG refrigerator error code Er FF - ApplianceBlog
https://www.applianceblog.com/mainforums/.../8302-LG-refrigerator-error-code-Er-F...
  1. Cached
  2. Similar
Mar 31, 2007 - Hey guys, This LG has me stuck. I have run the smart board entirely through the diagnostic mode and it says everything is OK - hours later a code comes up "Er FF" Model: LRSC26922TT Serial: 407KRPV00464 I have had no luck finding any useful info on the web.... nothing but horror stories about LG. FIXED LG Refrigerator LFXS32726 - Error Code E rF 3 Aug 2016 LG LFX31925 drain iced up (ER FF code) - How to remove freezer ... 24 May 2016 FIXED LG LFX31925ST Giving error code ER RF 3 Sep 2013 Kenmore elite refrigerator error code er FF 3 Mar 2013 More results from www.applianceblog.com
LG REFRIGERATOR REPAIR. HOW TO REPLACE FREEZER FAN. FF ...
9k=? 4:42 https://www.youtube.com/watch?v=Yiifd2sTrZI
  1. Similar
Jan 3, 2013 - Uploaded by SOCALAPPLIANCE LG Refrigerator repair. FF error code / ee ff . Bad freezer fan. Bad evaporator fan. How to repair an LG ...
Mar 22, 2018 | LG Refrigerators
Kenmore elite bottom freezer refridegerator error code er rf
you could call a repairman but if it is fairly old then buy a new smaller refrigerator the smaller simple ones seem to last longer in the long run .
Jul 17, 2015 | Kenmore Refrigerators
How do you fix an e5e communication error on a frigidaire washing machine?
Hey friend, thanks for your inquiry!
I see your Frigidaire washer is displaying an error code "e5e". However, it appears "e5e" is an invalid error code. Let's attempt resetting your range. You can do this by unplugging it or flipping the household circuit breaker to the off position for roughly ten minutes. This usually clears false error codes.
If resetting the power does not correct the issue, could you please inform me of the new error code or if your dishwasher continues to display "e5e" you may want to seek assistance from a professional for proper repairs. -Matt
Oct 18, 2014 | Frigidaire Washing Machines
Error on display er ff
Hi, here are the error codes and meanings for your Refrigerator
Error Code, All Error Codes will have an ER on the left side, followed by the error on the right:
Er IF - Icemaker Fan Error - This can be caused by frostaccumulation on or around the icemaker fan. Unplug the unit for 3-4hours to allow this to melt off. If error code persists, call CustomerService.
Er FF - Freezer Fan Error - This can be caused by frost accumulationon or around the freezer fan. Unplug the unit for 3-4 hours to allowthis to melt off. If error code persists, call Customer Service.
For remaining error codes, try unplugging the unit for a couple ofminutes to reset the unit. If the error code persists, call CustomerService
Er FS - Freezer Sensor Error
Er rS - Refrigerator Sensor Error
Er ds - Defrost Sensor Error
Er dH - Defrost Heater Error
Er CF - Cooling Motor Error
Er CO - Communications Error
Thank you.
Jun 06, 2012 | Refrigerators
I have a Kenmore Elite Refrigerator, Model No. 795.77573600. The ice and water dispenser give the error message Er 1F. In searching online it appears that this problem is related to the ice compartment...
This is an error code for the icemaker fan motor.
If the control does not see a signal coming back from the fan motor you will get this error code.
Please see the image below from the service manual that explains the ER IF error code.
http://media.fotki.com/1_p,wkbwtkdqbqkgrkkxgtqsskgwtqkq,vi/ktfgsrbbdxktrrwffdr/1/1303472/5961857/image18067img-or.jpg
The ER IF code indicates a failure of the icing fan.
You may notice slower ice production but the other fans should be okay.
You can select the ultra ice option and see if the fan toggles on.
The fan or the control is bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 25, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Error Code ER IF
The Fault code of ER IF in this Refrigerator is caused due to a faulty or Not-Working or Failed Ice Maker Fan. When the Fan gets at a halt, the MCU immediately gives this code. Another but rare possibility is that the MCU is in its own is faulty and giving unreasonable codes on Panel. A recommend to call a Certified Technician to diagnose the Pints and take recommended steps to repair it.
Thank you, Have a nice day.
Sep 28, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Dishwasher er error code
I have a similar problem with my Frigidaire FDB4050LHS1. My Owner's Manual says to contact the Customer Care Center if the display shows "Er", "uF", or "CE". When I called them, Maria didn't have a clue what the codes meant - all she could do was give me phone numbers to authorized service centers in my area.
I managed to get ahold of a "SERVICE DATASHEET" P/N: 154718601. The error code "ER/ER" means there is a "switch failure"; "ER/CE" denotes a "Configuration Error"; "ER/uo" means "Vent will not close"; and "ER/UF" means "Fan not running".
The schematic only labels three switches - labeled "USER INTERFACE SWITCH", "DOOR SWITCH", and "FLOAT SWITCH". There is also a switch in the pump motor assembly. If either the door or user interface switch is faulty, then you probably won't be able to do anything other than call a repair service - unless you know how to replace these switches yourself.
If the float switch is causing the error, you might be able to run the "Water/Service Test". From "PF" (denoting a Power Failure) or idle mode (with no lights on whatsoever), press and hold the "DRY/AIRDRY" and "START/CANCEL" buttons at the same time for 3 seconds. This will start an 8-stage test that runs for about 7 and 1/2 minutes. The display will show which step the test is in until it shows an error code. Step 1 tests the water valve, which is where the float switch is located. If that switch is bad, you will likely see "Uo" displayed within the first minute of the test.
Aug 24, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Frigidaire 24 in. PLD3465REC Stainless Steel Built-in Dishwasher Logo
29,735 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Vitally Alcher
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
