The water is not hot enough to melt the soap packets
SOURCE: Dishes not thourghly cleaned on top sheelve
generally dishwashers rely on the pressure supplied by the water supply line. check to see if it is enough or if inlet pipe is of sufficient diameter for needed flow.in some instances i know of seperate lines needing to be run directly instead of coming off of supply to sink area.
SOURCE: dishwasher is not getting dishes clean. Water is
follow this link:
http://www.fixya.com/support/t2390397-dishwasher_acts_up
that guy gave me some good advice!
SOURCE: dishwasher water doesn't get hot enough
please check the thermostat and the heating element to do this you should open the back cover and top cover.to solve easy please take the help from the service engineer
SOURCE: I have a GU1200XTLQ1 dishwasher that is 3 years
you may not be getting a full tub of water. water valve could be bad or float could be stuck check water level after you here it stop filling and motor runs it should be toutching the float at the least.could have somthing in the intake of the pump or the impeller drive could be stripped
SOURCE: My new dishwasher leaves a
Check the incoming water quality. If water is hard and having calcium content this could happen. Use water softeners in the inlet water to the machine.
If dish washer salt compartment available fill with the special salt meant for dish washers.
Check rinse aid compartment and fill rinse aid. Or use two in one soap tablet.
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
