The Stanton STR8-60 is a direct drive record deck, so this shouldn't happen unless the platter was damaged but after a little research I found that the Stanton's can get a faulty chip which is meant to regulate the speed and therefore can make it spin erratically.
If you lower the tonearm to the record surface, and it just slides towards the center, chances are the stylus(needle) is either broken or covered with dust. Clean and inspect. For more information, please visit my website at audioserviceclinic.com. Thank you.
Turntables are simple if you've an amplifier with inputs labelled PHONO (not to be confused with audio plugs called phono or RCA) If your amplifier hasn't then the sound from the cartridge on the arm won't be good quality. To make it compatible with a line input usually labelled either that or AUX you'll need a phono converter box. There are quite high price ones but there are equally mid and even low-ish priced ones too. Look around online for Phono-to-Aux adapters, converters or whatever description and/or visit electronic stores like Radio Shack (still in the USA) or Maplins (UK) if you're near any.
Check that the power button isn't stuck partially depressed. If that isn't it, you've got issues inside the phone that are going to require qualified service, or an internally damaged battery.
the 45 button is known as a push button switch. If the switch is affect, replacing should remedy, but it could be possible that the voltage variation on the motor is affected.
