Open your Web browser and type "192.168.0.1" (without quotes) into the address bar. Press "Enter" on your keyboard to access the router. A login prompt appears.
Enter your username and password to log into the router.
The router's main menu loads.
Navigate to the Maintenance heading of the Main Menu page.
Select "Set Password." The "Set Password" menu appears.
Enter the router's old password into the Old Password field.
Type the new password into the New Password field. Verify the new password in the Repeat New Password field.
Click the "Apply" button to apply the change.
Push the "Default Reset" button on the back of the Netgear WGR614-V6. The button is located on the back of the unit, to the left of the external antenna. You may need to use a pin or the tip of a pencil to access the button.
Continue holding the button in until you see the "Power" indicator on the front of the unit turn off and back on.
This takes approximately ten seconds.
Let go of the button.
The Netgear WGR614-V6 shuts off and turns back on. Allow several seconds for this process to complete.
Log into the router using the default password by opening a Web browser and navigating to the address "192.168.1.1." Enter the password "password" to log in.
hope this helps
or if its the WGR614-V6 model
