Stoves Premier 720GRa Gas Double Oven Logo
Sinead Walsh Posted on Apr 21, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Changing the light bulb in the oven
Can you tell me how to remove the oven light bulb from the described oven. Its in a white ceramic socket and will not turn freely or give when pushed in. Afraid to force it in case I break bulb so thought best to ask someone who knows! Many thanks
  • 1 more comment
  • Sinead Walsh Apr 22, 2007
    Many thanks for that. It was indeed just jammed and has been replaced sucessfully!
  • Anonymous Feb 17, 2008
    How do I remove the glass covers without damaging them to enable me to change the light bulb
  • thecoach Feb 17, 2008
    How do I remove the glass covers to access the oven light bulbs, without damaging them, to enable me to change the bulbs?
douglas smith
Level 3:
President:
  • Master 1,462 Answers
  • Posted on Apr 22, 2007
douglas smith
Master
Level 3:
President:
Answers
1462
Questions
0
Helped
898747
Points
3964
The light bulb is screw type so turn only. with heat, bulb can jammmed over time so you may have to break it and get a pair of plyers on the cap. turn off power to do this
How do I change the bulb inside the cooker of the B5741 cooker
Oven Lighting
Warning: There is a danger of electric shock! Prior to changing
the oven light bulb:
  • Switch off the oven!
  • Disconnect from the electricity supply.
Place a cloth on the oven floor to protect the oven light and glass cover.
Replacing the oven light bulb/cleaning the glass cover
  1. Remove the glass cover by turning it anticlockwise and then clean it.
  2. If necessary:
Replace bulb with a 40 watt, 230 V, 300 °C heat-resistant
oven light bulb.
3. Refit the glass cover.
Dado
Apr 15, 2015 • AEG Ovens
HOW TO REPLACE THE LIGHT BULB IN MY OVEN
Oven Lighting
Warning: Risk of electric shock! Prior to changing the oven light bulb:
- Switch off the oven!
- Disconnect from the electricity supply.
Changing the oven light bulb/cleaning the glass cover
1.Remove the glass cover by turning it anti-clockwise and then clean it.
2.If necessary: replace with 25 watt, 230 V, 300 °C heat-resistant oven lighting.
3.Refit the glass cover.
24472822-skr3uzd4ii43xzwyhmpsswym-3-0.jpg Dado
Replace light in KEMC378KSS microwave
The oven lights are 12-volt, 5-watt maximum halogen bulbs. They
will come on when the oven door is opened. On double oven
models, both upper and lower lights will come on when either
door is opened. The oven lights will not work during the Self-
Cleaning cycle. When the oven door is closed, press OVEN
LIGHT to turn them on or off.
To Replace:
Before replacing, make sure the oven is off and cool.
1. Disconnect power.
2. Remove glass light cover by grasping the front edge and
pulling away from oven
3. Remove bulb from socket.
4. Replace bulb, replace bulb cover by snapping back into wall.
5. Reconnect power.
Have a bulb broken off inside socket in gas oven..cannot remove..need help
power down at the breaker or unplug the oven,then if possible you can remove the lamp cover and shell from the rear oven wall,then most lamp bases have spade terminal connections unplug these remove the whole lamp base with the broken lamp,remove the broken bulb base,then check the center power tab inside the lamp base to make sure it isn't flattened out too much,otherwise carefully bend it upwards to make sure it makes contact with the bulbs base then re-insert the terminal connections and new bulb into the opening at the rear of oven,then replace the bulb,but,do not over tighten new bulb as this leads to non operation due to heating
WANT T REMOVE BASE OF BROKEN BULB STILL IN SOCKET RANGE
Unplug the oven. Take a potato and cut it in half. Jam it into the socket as far as you can. Now unscrew the broken socket by turning it counter-clockwise. The potato will form to the inside of the socket and twist it out.
How to change oven light
Which model Whirlpool range do you have? For most Whirlpool ranges that I have used , the oven light is covered by a screw-on glass cover. When the oven is cool, unplug the range, open the door and turn the cover counter-clockwise (to the left). Then remove the 40W bulb (again counter-clockwise rotation). Replace the bulb with another 40W appliance bulb. Then replace the cover by turning it clockwise until it is tight. Do not over-tighten either the bulb or the cover. Then plug in the power cord for the range. (Unplugging the unit makes sure that you will not get shocked if anything goes wrong. Sometimes the bulb may break in the socket - in that case, use pliers to unscrew the base of the bulb before replacing it with a new bulb.)
Whirlpool has the manuals for most of their appliances on their support site: https://www.whirlpool.com/webapp/wcs/stores/servlet/OCManualsLiteratureSearchView?catalogId=10561&langId=-1&storeId=10211&krypto=5QgxQhneFliXuEuX564wSQ%3D%3D&ddkey=http:OCManualsLiteratureSearchView .
I hope this helps.
1helpful
Replace oven light
If the metal sleeve that the bulb screws into is damaged, you can go to a local appliance repair shop for a replacement. Be sure to unplug the stove before doing any work on it. you will need the make and model of your oven to make sure you get the right part.
In the future, if the bulb detachs from the base on any light you have, 1) disconnect the power, 2) using a small wooden dowel or the plastic handle of a screwdriver that will fit inside the base, apply enough pressure while turning to remove the base. Good Luck.
Aug 06, 2009 • Ovens
Oven light bulb stuck in socket
You can use a potato (no kidding). Try to press firmly with a potato into the light socket and turn.
6helpful
2answers
Whirlpool Super Capacity 465 oven can't figure out how to change the lightbulb and it is not listed in the owners manual. Can anyone tell me how to remove the lightbulb cover?
The glass lens cover for the bulb is usually screwed into the socket so turn it counter clockwise and see if it comes off. When replacing the light bulb, press the door switch to ensure no power is going ot the bulb socket to prevent it from damaging the new bulb.
Mar 07, 2009 • Ovens
The oven light is out
Facing the head of the bulb...away from the base...turn it counterclockwise....that is..to the left. If you like, use a rubber glove to protect your hands in case it shatters. Use a slight jerking motion to break it free.
Right when you're trying to remove an old light bulb, it breaks on you, leaving a base stuck inside the socket. Here's how to remove it quickly and safely.
Step1Turn off power to the bulb and unplug the lamp. Step2Put on protective gloves. Step3Grip the metal lip of the bulb with needle-nose pliers. Step4Gently unscrew the bulb base, turning it the same way you would an unbroken bulb. Watch your fingers while turning the bulb base. Sheered glass remnants may still be inside. Step5Remove the bulb base from the socket. Step6Be sure to vacuum up any broken glass from the floor.
Top Stoves Ovens Experts
ZJ Limited
ZJ Limited
vince
Are you a Stoves Oven Expert? Answer questions, earn points and help others
