Tried turning off and on. light on but not cooling fridge part
If the power is on and your refrigerator is still not cooling, the problem could be as simple as a covered vent or something more complicated that requires the help of a service professional.
Is your thermostat set incorrectly? It's possible to accidentally bump the thermostat, so check it and reset, if necessary, to the proper coolness.
Is your refrigerator crammed with items or are air vents covered? Overfilling, especially near vents, can prevent cool air from flowing around items. Reduce the amount of food and drink inside your refrigerator, and be sure to leave vents clear.
Are your door gaskets damaged or worn, allowing cool air to escape? Try this test of your gaskets: Place a piece of paper or a dollar bill between the closed door and the refrigerator frame. If you can pull it out easily while the door is closed, it's time to replace the seals.
If there's ice on the evaporator cover, it's a sign that the evaporator coils inside could also be covered in ice and frost, indicating a defrost problem. Try unplugging the fridge and defrosting it before calling for help.
Is the compressor (the football-sized case on the outside back of the refrigerator) making a continuous hum or other noise? A constant noise could indicate a serious problem with one or more components. This is a repair that should be left to a refrigerator service expert.
If you hear a clicking noise every few minutes, this means your condenser is trying to work but can't. To see if a dirty condenser is to blame, check the condenser coils. These are usually found on the back or the underside of the refrigerator. If they are dirty, clean them. For instructions, see How to clean refrigerator coils and fan.
For more help identifying the causes and solutions, read Refrigerator not cooling or watch the video below. I hope this helps!
