Anonymous Posted on Sep 19, 2012
Receiver flickers on but then immediately powers back off
  • Anonymous Sep 19, 2012
    Obviously looked at power cord and it is plugged in and outlet is operating. Any ideas if this is an internal problem or a wiring issue?
Francisco Mauricio G
Level 3:
Genius:
  • Sherwood Master 1,551 Answers
  • Posted on Sep 20, 2012
Sherwood Master
Level 3:
Genius:
Answers
1551
Questions
Helped
524985
Points
4192
The audio amplifier IC's are damaged that's the reason the device going back to stand by
Screen first flickering then gone blank. Model LA40D550
Please be more precise:
Does this happens after immediately pressing the power button, during booting or at windows start up.
Casablanca intellitouch 3 light flicker
Call Casablanca at 1-888-227-2178
Feb 19, 2013 • Dryers
Proscan 40LC45S screen flickers, red light flickers, won't turn on
check bad component parts at the power supply board as will as burnt parts.
Magnavox mf310bf/7 tv when i try to turn it on the green light flickers but immediately turns back red. What could be the cause of it
It is indicating either a problem with the power supply in the set or something pulling voltages in the supply down.
Someone needs to open and check power supply in the set
My advent 8315 laptop will not turn on after i left it on all night. I charged it up immediately after but it will not turn on. when i press the power up button, the blue light flickers on and then turns...
Could be in short circuit protection mode, or for some reason your laptop is not receiving the correct power it needs. It is possible that it overheated and died because it was left on for a long period of time. This is confirmed if dust is present within the laptop. If under warranty return it, if not take it to a computer technician.
damnor01
3helpful
When i push power button clicks on immediately
I had this problem also and discovered an easy way to trick it into powering on: Click the power button, then within 1 second of the receiver powering off, click the power button again. The receiver should stay on this time. This works with both the button on the receiver and the remote control.
I would like to know what causes this problem and whether or not I should be concerned about damage being done. I assume this is a power protection. I haven't tried plugging this receiver into a different power socket to test, but I don't think the power plug is the problem. Note: I have the subwoofer plugged into the power plug on the back of the receiver.
Instrument panel on-off flickering batery light
I would check the alternator. Check the battery terminal connections to make sure they are tight. My immediate response remains to check the alternator.
My Dell latitude Cpx laptop just does not power up, just flickers
I had the same problem on my CPx. It turned out to be a bad memory module. With bad (or no) RAM, nothing is going anywhere, so it immediately shuts down. New memory, no problems.
Immediate shut
Unplug all the speaker wires first, then unplug the unit from the wall for at least 24 hours, The plug back in without the speaker wires or anything else plugged in. Then see if it goes to the protection mode. If it does not, plug in each speaker at a time, and see if any speaker, when hooked up, makes the receiver shut down. If it does shut down, My friend, I'm afraid you will need to take this unit into a repair shop, OR get a new unit. Good Luck
Top Sherwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Ngoro
Arnie Burke
Arnie Burke
Are you a Sherwood Audio Player and Recorder Expert? Answer questions, earn points and help others
