Mitsubishi VS-45607 45" Rear Projection Television Logo
Vs-360 horizontal line across the middle of the screen, audio ok
5 Related Answers
Anonymous
  • 11896 Answers
  • Posted on May 09, 2009
SOURCE: Mitsubishi TV had horizontal lines across the screen and rolls up
Answer
ONE: Yes, the speaker mounted close/near to the set can be a cause of mischief; please move it further away and see if that helps clear up the problem. But, you must keep it away for several days before you will know for sure because it takes some time to degauss all the internal parts that may have become corrupted by the magnets in the speaker.
TWO: Yes, any set can be repaired the question is cost and wisdom. Old sets are sometimes not worthy of the repair simply because of the likelyhood that another failure will follow soon after. A big screen always invokes a repair charge of $200 and up. After a few of these you will wish you had put all the money into a new set!
THREE: The lines are most likely a problem in the vertical blanking circuits of the set. These are horizontal retrace lines that are supposed to be blanked out during vertical retrace of the raster. Think of it as a paintbrush that scans across the screen painting thin lines and when you get to the bottom of the screen it goes quickly back to the top, but during that time the horizontal, which is many times faster, has made several sweeps; so it must be blanked out during the retrace. The repair involves finding the guilty parts and replacing them. Usually this repair runs over the $200 somewhat.
FOUR: Prior to calling in a service tech try a hard reset to see if that will recover any of the circuit degradations. Merely unplug the power cord and leave unplugged for 4 hours or more. It may help. Or, it may not help; but worth a try since is won't cost you anything.
If the set is over 5 or 6 years of age it probably is not a condidate for any expensive repair. On the other hand, it is a Toshiba - and they make a fine set.
Hope this helps. Let me know if you have further thoughts.
Anonymous
  • 64 Answers
  • Posted on Aug 01, 2009
SOURCE: i get lines running across my television
Sounds like interference or signal contamination. Does it occur on OTHER inputs? If not..then the input signal is corrupt, weak, has interference, wrong cable, or othewise defective.
nicknovikov
Nick Novikov
  • 101 Answers
  • Posted on Jan 29, 2010
SOURCE: Mitsubishi Big Screen TV has horizontal lines on start up
need replaice capacitors in vertical output cir.
Anonymous
  • 5138 Answers
  • Posted on Feb 17, 2010
SOURCE: Mitsubishi #35401 has only a
Sounds like Vertical collaspe, Problem is in your Verical circuit
I need you to look on back of TV for correct Model number WD?
Thank You.
Kenneth Lee Sr.
  • 597 Answers
  • Posted on May 31, 2010
SOURCE: Mitsubichi HD 1080 65" three colors like rainbows across screen
convergence problem...very common
Tv has horizontal line in middle of screen,sanyo ds25390
hi if only a horizontal line across with no video anymore, you have bad either vertical ic or no dc supply b+( vertical ic ) or no output dc coming from the ic. if it is not totally a horizontal white line and you can see a video you must check leak or bulged capacitors at the vertical section near the vertical ic. hope this can help good luck.
Horizontal lines across the screen
actually it is called a dead pixel. You can't fix it unless you will replace your LCD. Sorry for the bad news but it is for a fact. Hope I have answered your question
Horizontal lines across middle of screen sometimes
Vertical problem coming from bad solder, or vertical circuit problems!!!
Check for bad solder and capacitors problems in vertical circuit.
Black horizontal line across the middle of the plasma TV screen
It could be a defective Y-Buffer board, or a defective Plasma panel.
1helpful
2answers
Audio ok, no video
I’ve never seen this kind of video output caused by a bad video cable or bad FL inverter board. it was fixed after I replaced the monitor
I have a mitsubishi projection tv vs 6021 manf date may 1998. I have no picture no audio. the power swithc light is green and contiously flashes. Deos any one know what is wrong with it. thank you Denna
3 things will cause this and one wil be the problem. first off flashing green indicates protection mode.
Check for a faulty vertical chip. usualy removing it and briefly turning on the set will make the set work with a line across the middle of the screen. If the chip is the fault please replace the capacitors around the i.c as the fault will reaccur.
next check the horizontal out transistor , it should not be shorted between base and collector. if so check for dry joints around flyback trany and horizontal stage circuit.
last is the 8 volt regulator that supplies the micro its power. located on the power module.
Sharp 27G-S60
it is cery simple as it folds after an hoyr or so. as you are asking for the section where the problem is located so is in horizontal oscilattor section.(possible cause cap.might be defective.) as per ckt diagram is concerned is concern please seeweb site www.serviceinfo.com hope this will help
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
