Hi ,I bought 60 tvs from lasvegas hotel and they all programmed with only air channels and all menu function and setup is locked i cant not change anything by tv and they did not give us any remote ,i tried with some universal remote but it did not work ,what should i do now ? pls help me i am losing business i cant rent any rooms rite now with out tv
SOURCE: cant change channels
Your in the video mode so you have to change the input. On the original remote, its the button left of the power button. A universal may not work for this. If you need the original remote, Its available at http://www.remotes.com Good Luck
SOURCE: Philips tv
you probably need a hotel master remote, i.e. the philips rc2573gr:
http://salestores.com/philipsr.html
SOURCE: zenith tv wont unlock
It should be a good enough reason for an exchange if possible. And should be covered under warranty, if not. However, if you want to try and fix it yourself......
Yes there should be a "hidden" menu. Before you access it, I want to warn you, do NOT change any values of anything you don't understand what it is or does. You can PERMANENTLY DAMAGE YOUR TV. Also, write down the original values of anything you change before changing it!!!!!
If you still want to proceed(at your own risk), here ya go.
1. Press and hold the menu button until
the menu comes up on screen and then
times out (5 - 10 seconds)
2. Immediately press 9, 8, 7, 6, Enter.
3. The set should now be in the service menu
mode. To access most of the features
selection 00 needs to be toggled from 0 to 1
4. After your adjustments 00 needs to be
toggled from 1 to 0
5.Feature 16 unlock the auto-program (change to 0)
SOURCE: Remote not fully functional
You can get an original remote for this model at these following links:
Philips 30PW9100D Replacement Part Remote Control
Philips 30PW9100D Replacement Part Service Remote
SOURCE: LG RU-27FB30C. It's blocked.
http://www.newtvremotes.com/Mfrs/Zenith/ZenithTV/LP702.htm
VISIT THE ABOVE LINK AND ALSO SEARCH
RU-27FB30C on internet and you will get the manual
